Home > Maintenance & Mods (L322) > Air Conditioning not cold
Page 1 of 3 123>
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
I switch my air con on, the revs dip a little as expected when idling but nothing really cold comes out, when I compare to my Mazda, which is ice cold (2005) in a minute or two. Is it simply a case of having to re-gas them?
Post #321933 9th Apr 2015 2:59pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Sounds like it is due a re-gas or at least a health check Very Happy Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #321934 9th Apr 2015 3:08pm
ebajema
I agree, it could be the liquid phase is almost gone, so enough pressure to keep the system working but not enough liquid to cool. Had it on my 4.2 SC as well, just a bit of R134a in it and cool air in 10 minutes Wink MY 2010 5.0 SC Galway green and sand interior!!
Post #321937 9th Apr 2015 3:29pm
scwilson
So can this be done yourself with ease? If so, which product or would Halfords do something like this?
Post #321938 9th Apr 2015 3:37pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Sounds as though you have a leak on the system somewhere. Current regulations require that a loss of refrigerant is traced then rectified and the system vacuum tested before being refilled with new refrigerant . Beware that some of these so called experts will just top up for a few bob and send you on your way, this is false economy as modern gases are in fact blended from different gases and have varying molecular size and therefore the smallest molecular gas will leak first rendering the remaining gases useless. Just topping up will result in a return to the garage in short time and is also illegal. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #321939 9th Apr 2015 3:41pm
scwilson
ok thanks.
Halfords have quoted for £49 at a garage they own, attached to their store that they check for leaks and pressurize for 45 mins and if there are none, they re-gas.
Post #321940 9th Apr 2015 3:52pm
scwilson
I am wondering now whether to just do it myself;
http://www.halfords.com/motoring-travel/en...nser-gauge
http://www.halfords.com/motoring-travel/en...g-recharge
Post #321943 9th Apr 2015 4:04pm
Pfazz
I take it you did not understand my reply above. Agueroooooooooo. 93-20
Post #321948 9th Apr 2015 4:23pm
scwilson
Well I thought I did ... was planning on checking the pressure myself and topping up. If this was illegal, I suspect Halfords wouldn't be allowed to sell these bits to diagnose.
Post #321950 9th Apr 2015 4:30pm
I strongly recommend you don't try and refill the ac system by yourself using one of the above kits.
If your system is low on gas, which seems likely, you need to have the system checked and refilled professionally. You have absolutely no way at this stage whether the system has a leak which may or may not be the case and which may or may not need to be fixed before proceeding further. Equally you have absolutely no way of knowing , in terms of refrigerant and oil, what is in the system at present.
The only guaranteed way to satisfactorily re-gas an ac system is to remove what is left, check it's vacuum holding capabilities and then if all is well proceed to refill with the measured amounts of refrigerant and oil and probably a leak inhibitor.
I'd go for the £49 offer from Halfords, with the equipment they have they are surprisingly good at this particular job.
It's a good price, even Kwik Fit provide the same service.
Post #321953 9th Apr 2015 4:46pm
Pfazz
It is not just like blowing a tyre up, a certain volume of gas as a liquid has to be put in the system. The way to do it properly is to have an empty system and fill from a known weight of liquid. Also to top up as I said before results in an unequal and useless blend of gas. If it is leaking now it will leak again when you top it up your way and just make things worse. Agueroooooooooo. 93-20
Post #321957 9th Apr 2015 4:50pm
DMRR
I use professional air con people - i.e. that's their sole business and that's where our local LR dealership take your vehicle! They aren't hard to locate and they are VERY thorough. Halfords....sorry but I'd look harder. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #321969 9th Apr 2015 7:00pm
Rangeyman
I agree with Dmrr,have a ring round and get it done professionally,my mate used the 'Diy kit' on his car and it didn't work so he ended up paying someone who knew what he was doing and it worked a treat.He even told him that most people who think their air con was working good will be surprised just how much cooler it will be with a professional service.!!
Post #321974 9th Apr 2015 7:41pm
A good tell tail that you have lost enough gas to lose the liquid phase is at idle you will here the compressor click in and it will make a whirring sound ,fully gassed up it will be quiet , and as above go to a professional you know it makes sense . 2008 MY Supercharged
Post #321999 10th Apr 2015 1:31am
Pfazz
I wonder how Halfords and the kit manufacturers get around this.........
Achievement of this qualification allows experienced MAC Technicians (working with cars and car-derived vans) to continue to practice after 4th July 2011.
All MAC Technicians must have achieved (as a minimum requirement) a refrigerant handling qualification (approved by DEFRA), meeting the EU F-gas regulations.
On and after this date, in order to legally recover F-gas (fluorinated greenhouse gas) from air conditioning systems in motor cars and car derived vans.
Excerpt from course requirements.
Post #322002 10th Apr 2015 5:59am
Page 1 of 3 123>
