Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
It's looking that way..... Pete
8th Apr 2015 1:06pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
It's certainly very disappointing what you've found up to now. The whole transmission sounds, to put it kindly, very tired - and the cowboys that previously rebuilt it haven't helped.
8th Apr 2015 1:45pm |
Cheers Phil, I'll have a look round....
8th Apr 2015 2:48pm |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 |
Hi
8th Apr 2015 3:31pm |
Thanks for your kind offer, I'll have a good look around and see whats on offer.... that LHD one was at a local place and it's gone now so still looking.... Pete
8th Apr 2015 4:46pm |
RRPhil, I've sent you a PM.... Pete
8th Apr 2015 4:48pm |
You could still buy my 2003 FFRR V8 2017 MB V-Class
8th Apr 2015 8:08pm |
Yes, as heppsen has already stated, there’s no difference between LHD & RHD models as far as the transmission is concerned. On the ‘032’ Range Rover model both the selector lever and the inhibitor switch are on the RH side of the transmission. On the BMW X5 (‘029’ & ‘034’ models for the 4.4i and 4.6iS respectively) the inhibitor switch is on the RH side but the selector lever is on the LH side. Other BMW models with the 5HP24 have both the lever and the switch on the LH side.
8th Apr 2015 9:32pm |
Cheers Phil and heppsen, thought I'd read somewhere they were different....
9th Apr 2015 1:11pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Good luck Pete - Looks a decent box. |
9th Apr 2015 2:25pm |
Cheers, the filter is dated June 2014 so not been in long....
10th Apr 2015 2:29pm |
Hmm, that is a bit higher than usual. EPRS1 is the ‘green cap’ main pressure solenoid and its winding resistance is usually around 0.5 ohm lower than the four other ‘black cap’ EPRS solenoids.
10th Apr 2015 2:54pm |
Pete,
10th Apr 2015 3:12pm |
Cheers Phil, they all measured at the top of their range, it could be a low battery in my meter.....
10th Apr 2015 5:59pm |
