Home > In Car Electronics (L322) > 2009-2012 4.4L L iPhone cable and iPhone 6 compatibility |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
I would like to connect my iPhone 6 to my 2012 L322.
27th Dec 2014 5:33pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Apple do a gen 30 pin to lightening adaptor, the problem is the 5 and 6 only output digital stream from the plug on the bottom, so the El cheapo adapters don't have a dac built in hence the 3.5mm jack built in to the cheaper ones. The cheaper ones only function as a data cable adaptor, whether the lr cable takes a digital stream I'm not sure tbh but a fully functional adaptor would be preferable.
27th Dec 2014 5:49pm |
RichTDV8 Member Since: 16 May 2010 Location: Surrey Posts: 52 |
I have gen RR fat plug with gen Apple coverter (£25) sucks when you buy it as £25 for a bit of plastic is dear but it does work and provide full function 3.0 VSE - 2015MY
28th Dec 2014 11:47am |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 |
Has this found a solution?
27th Mar 2015 5:42pm |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 345 |
Also interested in any update on this |
29th Mar 2015 5:17pm |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
http://www.amazon.co.uk/ViseeO-Tune2air-WM...s=tune2air
30th Mar 2015 8:10am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Andy, how does it work in relation to the Phone? Do you need to plug one of the boxes into the car & one into the phone? Or does the phone just stream to the one box plugged into the car? |
30th Mar 2015 8:24am |
Hi Craig,
30th Mar 2015 8:31am |
30th Mar 2015 8:47am |
Nice one
30th Mar 2015 9:00am |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 |
I have the same thing - brilliant and fault free to date. 2017 Range Rover Vogue SE SDV8 (with e-diff)
1st Apr 2015 4:22am |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 |
I also use this Tune2Air from Amazon. It works perfectly and in parallel to the Handsfree Calling functions. |
1st Apr 2015 5:30am |
I have successfully connect my old Ipod Nano to the genuine cable and it works fine.
2nd Apr 2015 5:22am |
Slaav Member Since: 02 Mar 2014 Location: GLos Posts: 32 |
Chaps, that product doesn't appear to be available anymore...
1st Nov 2015 11:50pm |
