Home > In Car Electronics (L322) > "Special programmes off"
Dimax
England 2012 Range Rover Autobiography TDV8 Santorini Black
I recently had a flat battery and had to replace it. Since then "Special programmes off" comes up on the message centre when starting. Any suggestions how I switch "Special programmes" on? Also the timed climate won't work with the remote, which it did before. Is this related?
Post #417029 7th Dec 2016 5:03pm
Did you replace it with the right spec battery ?
I've only heard of that message at standstill with a dodgy battery.
If you get it under hard acceleration, then it usually points to turbo/intercooler hoses being slit.
Post #417030 7th Dec 2016 5:07pm
Dimax
The battery was actually replaced by the AA so I would hope it was the correct one! The receipt hasn't arrived yet so I can't give you the actual spec. We have breakdown repair cover so it only cost us £30 but he said it would have been £180 otherwise so I don't think it's a cheapo. Everything else is OK. The message only shows briefly when starting.
Post #417032 7th Dec 2016 5:16pm
I'd start by fully charging the battery.
Read & clear all fault codes if you have an IID or other device that is capable of doing that.
It could also be pointing towards a failing alternator - the 2007 TDV8 seems to have a weak alternator with lots having failed.
There may be more clues using search
Post #417037 7th Dec 2016 5:45pm
Dimax
Thanks, I can't read fault codes but I know a man that can so I'll start there.
Post #417041 7th Dec 2016 6:03pm
There is lots of info on here about what to look for voltage wise when the alternator is starting to go. You can monitor it by using the hidden menu on the head unit screen. There is nothing that can't be fixed with a hammer😜😜
Post #417066 7th Dec 2016 9:49pm
Dimax
Intriguing! How do I get into the hidden menu please.
Post #417118 8th Dec 2016 12:16pm
http://www.fullfatrr.com/forum/topic32791.html Thumbs Up
Post #417148 8th Dec 2016 3:28pm
Dimax
Thank you. I had searched the forum but it didn't come up.
Post #417167 8th Dec 2016 5:42pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
have you had fault codes read yet ?
Post #417169 8th Dec 2016 5:49pm
andygts
It's voltage related. Special programs should be off under normal conditions. To turn them on you need to select sand etc with the terrain response knob. When you switch back to the road setting it will say special programs off.
Probably got a slightly smaller battery on than it should have or the starter isnt the healthiest and it's putting more load on the battery that normal. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #417170 8th Dec 2016 6:15pm
Put up a pic of the battery label and I'm sure someone will be along to say if it's good. There is nothing that can't be fixed with a hammer😜😜
Post #417177 8th Dec 2016 6:46pm
Dimax
Thanks to all for your help. Unfortunately I'm busy at work at the moment but as soon as I can I'll get a pic of the battery. The man who can read the fault codes has gone and Censored off to the States 'til the New Year - you just can't rely on people can you Laughing
Post #417195 8th Dec 2016 8:15pm
Dimax
Here's a pic of the new battery
Post #417272 9th Dec 2016 4:02pm
Not a bad battery by any stretch of the imagination. Some have fitted the Bosch battery which is 110AH and 920amps. The breakdown service have fitted a 100AH 900A, this is a little more than the standard battery (90AH and 850A) which is good, but not as much as the what can be fitted in the guise of the Bosch, it should work fine so long as your alternator doesn't fry it. I had a similar capacity Bosch in my 3.6 and it worked well until the alternator went and took the battery with it. There is nothing that can't be fixed with a hammer😜😜
Post #417277 9th Dec 2016 5:02pm
