Home > In Car Electronics (L322) > 2009-2012 4.4L L iPhone cable and iPhone 6 compatibility
Page 1 of 4 1234>
verydisco
I would like to connect my iPhone 6 to my 2012 L322.
L322 came with the iPhone and usb plugs in the cubby box.
I would like to use the full fonctionnality with steering wheel buttons, but there is not yet a dedicated cable it seems. So I wanted to use a Jaguar/LR cable for Iphone 4 & 4S then add an adaptor for the new iPhone 5S/6 plug.
Did anyone try this already as it may not work by simply using an adaptor.
here are the said parts :
JLR type cable (for Iphone 4/4S):
http://www.ebay.co.uk/itm/Land-Rover-JAGUA...1e973ee571
Would I then need this :
http://www.ebay.co.uk/itm/Charger-Data-Ada...2a490a2c56
or this with audio jack?
http://www.ebay.co.uk/itm/iPhone-4-to-iPho...2edaaf9483
or even this
http://www.ebay.co.uk/itm/White-Cable-30-p...2c7e929c9d
The plan is to have the iPhone 6 handy by the cup holder or dedicated holder, not simply in the cubby box once plugged. I need apps handy while in the car.
If there are alternative to use the iPhone music (stocked or streamed) say via bluetooth, please let me know. I would then simply run a hidden USB cable from the cubby box and only plug the iPhone 6 to it then Bluetooth music.
thanks l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #301147 27th Dec 2014 6:33pm
Apple do a gen 30 pin to lightening adaptor, the problem is the 5 and 6 only output digital stream from the plug on the bottom, so the El cheapo adapters don't have a dac built in hence the 3.5mm jack built in to the cheaper ones. The cheaper ones only function as a data cable adaptor, whether the lr cable takes a digital stream I'm not sure tbh but a fully functional adaptor would be preferable.
Pretty sure using the gen apple adaptor on the end of the LR cable would give the same functionality as with older 30 pin equipped phones. They cost around £25, from Apple Store.
http://store.apple.com/uk/product/MD823ZM/...4e328053fd There is nothing that can't be fixed with a hammer😜😜
Post #301148 27th Dec 2014 6:49pm
verydisco
Thanks
Will wait for further feedback/experience but will most likely do as you say and report then. Thanks for you help Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #301150 27th Dec 2014 6:56pm
RichTDV8
United Kingdom 2015 Range Rover Vogue SE TDV6 Corris Grey
I have gen RR fat plug with gen Apple coverter (£25) sucks when you buy it as £25 for a bit of plastic is dear but it does work and provide full function Previous
3.0VSE - 2015MY
Corris with Black, RSE, 22 turbines, privacy, deployables
2023 L460 P400 SE in silicone silver
2022 L460 P400 AB in black with ivory (deleted rear exec pack)
Post #301251 28th Dec 2014 12:47pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
Has this found a solution?
2012 FFR with connectivit pack and Iphone6
Charges via usb cable but no music through there.
I am still missing the genuine Ipod cable, but I guess this would be a 30 pin nit a lightening connector?
What would the correct part number be please?
Can I stream the music by some means? Wireless does not seem to be an option for the cars system?
Phone functionality works fine.
Thanks for input
Regards
Heppsen
Post #320072 27th Mar 2015 6:42pm
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Also interested in any update on this Thumbs Up
Post #320356 29th Mar 2015 6:17pm
Andy B
http://www.amazon.co.uk/ViseeO-Tune2air-WM...s=tune2air
Got one of these in mine, works well Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #320436 30th Mar 2015 9:10am
Andy, how does it work in relation to the Phone? Do you need to plug one of the boxes into the car & one into the phone? Or does the phone just stream to the one box plugged into the car?
Post #320439 30th Mar 2015 9:24am
Andy B
Hi Craig,
Using an I-Phone 4 lead from the USB port in the cubby, just plug the Tune2Air in. Pair it with the I-Phone using '0000' and Bob's yer Aunty! Gives you easy access to your phones entire music library. Thumbs Up
Cheers,
Andy. SDV8 AB MY 2019
Post #320444 30th Mar 2015 9:31am
Thumbs Up Bow down Bow down Bow down
Thank you sir Thumbs Up
Ordered Mr. Green
Post #320449 30th Mar 2015 9:47am
Andy B
Nice one Thumbs Up Thumbs Up Very Happy
Just realised it's not the I-Phone 4 cable, but the one that comes with the car Embarassed Embarassed
 SDV8 AB MY 2019
Post #320452 30th Mar 2015 10:00am
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
I have the same thing - brilliant and fault free to date. 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #320731 1st Apr 2015 5:22am
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
I also use this Tune2Air from Amazon. It works perfectly and in parallel to the Handsfree Calling functions.
Post #320733 1st Apr 2015 6:30am
heppsen
I have successfully connect my old Ipod Nano to the genuine cable and it works fine.
Does not show album names at present, but I will figure that out later on.
At this time I just enjoy having the music connected up to the 1200W HD system.
Will try and get one of the bluetooth thingies for the phone.
regards
heppsen
Post #320916 2nd Apr 2015 6:22am
Slaav
Chaps, that product doesn't appear to be available anymore...
Any suggestions vs the Apple connector/adaptor which I assume foes everything?
Thx in advance....
Post #354955 2nd Nov 2015 12:50am
Page 1 of 4 1234>
