Home > Technical (L322) > 4.4 V8 poor fuel economy
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
One thing of concern is fuel economy, now don't get me wrong I'm under no illusion that this was going to be anything else but a gas guzzler but it really does take the tiddle & not like I'm not used to running V8s. I have the RRC V8 & Last car was an audi Quattro 4.2V8 340 BHP that gave around 17mpg depending on if I drove it like it was stolen & that seems economical compared to this. I put £20 in the other day & only got around 20 miles, correct me if I'm wrong but shouldn't I be getting more that that?
I could live with 15/17mpg. I tried to work it out what I got, that £20 fuel is around 17 litres. Used an online calculator it tells me mine is doing 5.35 mpg Shocked
http://www.mpg-calculator.co.uk 2004 RR 4.4 V8 Autobiography
Post #318756 20th Mar 2015 8:44am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
To be really accurate you need to do a couple of tank to tank fills. If you can,use the same pump and only let it click once when full.
Enter the details into something like www.fuelly.com make sure you select UK MPG and go from there.....you need to go through a couple of tanks to get a true picture. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #318757 20th Mar 2015 8:59am
whats a RRC ? ... - .- -.
Post #318758 20th Mar 2015 9:06am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Your not ment to drive a RR like you stole it Laughing Laughing
My other V8's , 2 3.5's and the Disco a 3.9 are no where as economical as the FF, I get 14.7 most times on short trips or work and on a long run the best out of the old girl 25 mpg. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #318760 20th Mar 2015 9:08am
markcartlidge
Mine shows me as getting 17.9 currently and that is driving like miss daisy. When I first had it the mpg was closer to 20. I plan to do a fill with the high octane fuel to see if it changes either the performance or economy. Mileage and fuel records calculated over the last few months shows it to be more like 15.6
ODB shows some issues with O2 sensors which I should get checked out but not causing warning lights. Have you looked for any error codes?
Post #318762 20th Mar 2015 9:16am
Welshdragon
@ Stan RRC = Range Rover Classic. Whistle If it dont work.......burn it!
Post #318763 20th Mar 2015 9:16am
so its a 2003 RRC ? ... - .- -.
Post #318765 20th Mar 2015 9:21am
Doooooooooooh Embarassed Embarassed Embarassed
Post #318774 20th Mar 2015 9:41am
OP's is a petrol Craig Wink ... - .- -.
Post #318779 20th Mar 2015 9:51am
That'll learn me Stan! Embarassed Bow down Thumbs Up
Post #318781 20th Mar 2015 9:54am
verydisco
Rule of thumb when you drive/own a V8: fill it up when its empty, stop counting. Mr. Green
Works for me especially with MTRs, winch and roof rack. Whistle l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #318787 20th Mar 2015 10:12am
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
13 mpg all the time and i drive it hard 4.2 sc
Post #318937 21st Mar 2015 10:53am
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
Doing around 15-17 mpg, same model and engine! L322 Vogue 2003
Post #318993 21st Mar 2015 9:08pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I got an average of 17 when I had a 4.4. I'm not an economical driver particularly. I don't think I could get it down below 10 without being chased Shocked
Definitely time for a check up I think... My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #318996 21st Mar 2015 9:17pm
wealy
Yes - can relate to that. I used to get 18 and that included motorway miles once a week
Post #319391 24th Mar 2015 11:32am
