Home > Technical (L322) > Blindspot mirror |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
No, you can just register as an independent. You get access to some basic info about your car (build specs etc) plus owners manuals. Like everything in life though, you pay for the good stuff (bulletins and repair info etc). You can pay by the hour though which isn't too terrible. My Previous RR's!
24th Feb 2015 8:41am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
free to register, free to look at the owners manual and fitting guides but you need a subscription to view or download any thing else.. ... - .- -.
24th Feb 2015 8:43am |
I definitely have the mirror fitted with the LEDs. It also appears to be wired up, but It isn't anywhere in the menus that I can see and has never lit up My Previous RR's!
26th Feb 2015 6:33pm |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 345 |
Ooh..best I go and take a look and see if I have this |
27th Feb 2015 10:05am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Yes you will have it |
27th Feb 2015 10:24am |
Well...yes I have ...everyday is a schoolday ,this car just keeps giving |
27th Feb 2015 5:29pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 490 |
BSM- some door mirrors have the symbols but system is not connected.
27th Feb 2015 6:53pm |
sorry - forgot to add, just becuase you haev fwd alert doesnt mean you will have BSM. Cheers
27th Feb 2015 6:54pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Indeed - I have forward alert but no LEDs or anything in the wind mirrors. Also nothing shows on the tat screen to activate it.
27th Feb 2015 9:35pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
wrong The BSM devices are in the rear quarter panels on each side just front of the rear lights. The workshop manual clearly show their location. If you look you will see that these quarter panels are made of plastic - as this does not interfere with the radio/micro sonic waves that the system is sending out motoring whats around. Both our L322 have plastic quarter panels - they are not alloy as I have tested with magnet. The square BSM system units can be clearly been seen when you take the inside carpet panels off. There is also a audio speaker system fitted on each side - I guess this is that makes the sound when something is getting near your ass - its time to put metal to the floor when they bleep hope this helps again[/quote] Last edited by EmiratesA380 on 1st Mar 2015 1:58pm. Edited 1 time in total |
1st Mar 2015 1:01pm |
Hi JST Have you tried or come across this: - I had this the other day on route to the airport - some Muppet decided to stop when turning off a bit sharpish - the Warnings came up on the dash board with the bleeps ( Ive got is set on Max scanning range ) - I noticed the brakes were being applied for me and the brake pedal was jerking under my foot when I applied the brakes - the same as you get when the ABS system is being activated very very hard. Is this another device when you are braking at the last minute to let you know the brakes are being applied ( as well as you ) - has anyone else encountered this - although I would not want to leave ALL THE BRAKING to all the car itself just incase it did not stop in time. |
1st Mar 2015 1:57pm |
what you are describing is part of the fwd alert system working in conjunction with emergency brake assist (EBA).
1st Mar 2015 7:46pm |
somchie Member Since: 31 Mar 2014 Location: G�teborg Posts: 42 |
I'm probably not helping
2nd Mar 2015 2:00pm |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Hi Somchie,
2nd Mar 2015 4:10pm |
