Home > Technical (L322) > Blindspot mirror
Page 1 of 3 123>
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Blindspot mirror
Anyone know anything about the 2010 blind spot mirror? It looks like I have this (VSE 2010) as the mirror has the space for the LED but nothing has ever lit up?? It's clearly not working but I've no idea why or where to start looking. I've looked behind the mirror glass and the wiring goes up to the area?
Any clues? My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #314330 22nd Feb 2015 12:50pm
Does yours have vision assist pack? (camera's)
Post #314333 22nd Feb 2015 1:25pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hi hoppy_70
I presume you are taking about the Blind Spot mirrors on each Passenger & drivers door.
When you are stationery - the 2 outside mirrors will have a Orange/Amber DOT illuminated. This shows the system is live.
When the vehicle is moving they go out - when a car over takes or comes near to the rear of the car you get 2 Amber illuminated cars appear in the wing mirror. & a waring on the LED instrument console with a buzzer warning.
any help ?
Post #314334 22nd Feb 2015 1:27pm
EmiratesA380
I s this any help to you:
Post #314337 22nd Feb 2015 1:34pm
hoppy_70
Thanks all. Craig, it doesn't have the vision assist pack, but does have the mirror and wiring. Did they fit this to all cars then, in anticipation of people buying vision pack? Seems wasteful? My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #314350 22nd Feb 2015 3:38pm
Have you activated it in the menu on the dash by a tick ... ====================================
Post #314360 22nd Feb 2015 4:46pm
verydisco
Hoppy, simply check your vehicle's specs on Topix -FOC and online Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #314369 22nd Feb 2015 5:41pm
EmiratesA380
Any help again ?
Post #314370 22nd Feb 2015 5:45pm
Im not sure Hoppy... I understood the vision assist pack was linked to the blind spot monitoring system and one meant the other etc... I thought the blind spot monitoring used the vision assist camera's to work the system! Please let me know your findings along the way Thumbs Up
Try as Joker says ticking it in your user display? Or if that does not work find someone to initiate it in the CCF files...
Is there any chance the mirrors could have been changed by a previous owner?
Post #314372 22nd Feb 2015 5:46pm
EmiratesA380
happy_70
You should have this on the LCD dash if its fitted - have a look
Ours are lit up green on both cars when engine is running.
again hope this is of help to you.
Post #314391 22nd Feb 2015 6:53pm
hoppy_70
Hmmm, that's forward alert?? I have that activated for when the wife isn't In the car (it beeps when you aren't braking fast enough (or at all).
Where do I find the tick?? My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #314397 22nd Feb 2015 8:20pm
EmiratesA380
happy_70
I think Joker means - the menu stick (selector arm on the steering wheel stalk) for on the LCD display - the menu of the car.
Tick = means SELECT IT
You should able to choose it from there
Post #314425 22nd Feb 2015 10:08pm
EmiratesA380
happy_70
Do you have when engine running - but stationery
A yellow/amber DOT in each door mirror lit up ?
Post #314426 22nd Feb 2015 10:10pm
hoppy_70
Hi, I'm not getting any LED either stationary or moving. I can't see an option to check or uncheck this, anywhere in the menus. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #314531 23rd Feb 2015 8:28pm
jeffw
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Do you not need to be in the trade to register on this site? 2011 4.4 TDv8 Vogue SE
Zeus Challenger Evo II
Post #314565 24th Feb 2015 8:33am
Page 1 of 3 123>
