Home > Technical (L322) > Is it bad for the gearbox to pull of in 2nd |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
On later MY's, you can pull away in 3rd
22nd Feb 2015 6:43pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
Mikey - I thought I'd read somewhere that under normal "setting off" conditions the car automatically selects 2nd gear and only uses 1st for those that require it.
22nd Feb 2015 7:53pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I'd say, keep it I DRIVE and let the transmission sort itself out.
22nd Feb 2015 8:31pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Mine normally sets off in second in moe most conditions when in D but will select first of the van is on the back. Or I floor it. There is nothing that can't be fixed with a hammer😜😜
22nd Feb 2015 9:13pm |
That's what I thought / believed but wasn't sure |
22nd Feb 2015 9:37pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Put your car in "D" and drive away from a standing start. Then put it into manual mode and drive away in both first & second and make your own mind up... Im sure my 4.4 TDV8 pulls away (in normal driving conditions) in 2nd & a flying start in 1st |
22nd Feb 2015 11:53pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
V10 M5 my dad had a few years back would always pull away in 2nd in D (smg box) thing was so powerfull its was near impossible to move it in first without the wheels spinning. Horrible transmission though only felt right when you hammered it, which was fun....... Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
23rd Feb 2015 12:02am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
My xkr jaguar defaults to second from a standing start? Why do they bother putting first there if it doesn't need it?? |
7th Mar 2015 11:49pm |
^ You may need that first when towing, starting on a steep hill or when you floor it. |
8th Mar 2015 7:07pm |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
My m3 smg will always pull away in 2nd if its in one of the lower modes (a bit like winter mode i guess) |
9th Mar 2015 11:03am |
