Home > Technical (L322) > Is it bad for the gearbox to pull of in 2nd
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Basically just what the title says. I just realiased today that I can put the car into 2nd and pull off. Just wondering if I should avoid doing this incase it puts extra stress on the box.
. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #314387 22nd Feb 2015 6:41pm
Mikey
On later MY's, you can pull away in 3rd Thumbs Up
It's best not to pull of in anything other than 1st, as it works the torque converter harder than it normally would Thumbs Up
Post #314388 22nd Feb 2015 6:43pm
RiccartonRR
Mikey - I thought I'd read somewhere that under normal "setting off" conditions the car automatically selects 2nd gear and only uses 1st for those that require it.
Is this complete baloney or perhaps the results of too much beer? Very Happy
Post #314392 22nd Feb 2015 7:53pm
RR2008HSE
I'd say, keep it I DRIVE and let the transmission sort itself out.
That say, in very icy/slippery conditions, pulling away in a higher gear can help maintain traction. If the FFRR has TR, then just let it be, but it's something to try in the other ones.
Post #314403 22nd Feb 2015 8:31pm
Mine normally sets off in second in moe most conditions when in D but will select first of the van is on the back. Or I floor it. There is nothing that can't be fixed with a hammer😜😜
Post #314413 22nd Feb 2015 9:13pm
RiccartonRR
That's what I thought / believed but wasn't sure Thumbs Up
Post #314417 22nd Feb 2015 9:37pm
Put your car in "D" and drive away from a standing start. Then put it into manual mode and drive away in both first & second and make your own mind up... Im sure my 4.4 TDV8 pulls away (in normal driving conditions) in 2nd & a flying start Whistle in 1st Thumbs Up
Post #314440 22nd Feb 2015 11:53pm
markcaughey
V10 M5 my dad had a few years back would always pull away in 2nd in D (smg box) thing was so powerfull its was near impossible to move it in first without the wheels spinning. Horrible transmission though only felt right when you hammered it, which was fun....... Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #314441 23rd Feb 2015 12:02am
wealy
My xkr jaguar defaults to second from a standing start? Why do they bother putting first there if it doesn't need it??
Post #316805 7th Mar 2015 11:49pm
RR2008HSE
^ You may need that first when towing, starting on a steep hill or when you floor it.
Post #316955 8th Mar 2015 7:07pm
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
My m3 smg will always pull away in 2nd if its in one of the lower modes (a bit like winter mode i guess)
Post #317083 9th Mar 2015 11:03am
