Home > Technical (L322) > Clunky changedown after full service (inc gearbox service). |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
After a gearbox oil change, the adaptive values should be reset, so the box can relearn all its values/pressures/ratios
21st Feb 2015 6:57am |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
Is the correct oil in? You don't say if it's main dealer or other? My last cars fear change improved hugely after oil change so definitely shouldn't have made it worse, even with a reset. My Previous RR's!
21st Feb 2015 8:06am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Wow... You might want to correct this post Micky! There is NO WAY the adaptions should be reset at the time of a gearbox oil change... That would be insanity! The gearbox would have no memory! Different viscosity of oil so different pressures to adapt too!Any worn gearbox (certainly the 6 speed) would go into self destruct mode! Im sorry but thats stupid advice to members who have an iid tool and the ability to change their own oil! |
21st Feb 2015 9:23am |
While trying to find out what the 3-4 shift problem with my 4.2 was, I also reset the adaptive values to see if that made any difference. It did but not in a good way, the shifting became quite unpleasant until the run-in sequence was completed (it is still in my gearbox post thanks to RRPhil). After the run-in sequence the box will shift a lot better then just after the reset and within a few days/weeks it is smooth as, well once the problem was sorted that is.
21st Feb 2015 11:02am |
If you reset the adaptions on a worn gearbox even without an oil change, you run the risk of it self destructing anyway
21st Feb 2015 11:09am |
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 |
Many thanks for the replies so far.
21st Feb 2015 11:33am |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 |
i learnt this when i reset my gearbox adaption settings, ended up having a new recon gearbox i wouldn't advise anyone to reset this on a worn gearbox.
21st Feb 2015 11:36am |
Engine running, gearbox oil temperature between 30-35 degrees, and undo the filler plug on the side of the gearbox.
21st Feb 2015 11:37am |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
When I had my transmission serviced at mackies a few weeks back I forgot to ask if they reset any software etc. But I think they may have. The car drives pretty much the same as before however the 2-1 rollout shift doesn't happen atol anymore. Before I had the service done my driving had adjusted to avoid this issue when at junctions etc but was sometimes unavoidable. But since after the service I have just drove as normal, actually almost trying to make the car do it and it just won't, problem seems to be completely gone and as far as I can tell it can only be software changes that could have sorted this as surely just new fluid wouldn't have that effect ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
21st Feb 2015 11:40am |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
Not wanting to hi jack the thread but this is a very relevant post for me. Car is now at 120,000 and no gearbox issues so should I run the risk of getting the oil changed and flushed. ? Re the jerk from 2 to 1 st I have had this on at least two FFRRs where this has been present. So are you sure it wasn't there before and you have only just noticed ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
21st Feb 2015 1:30pm |
I was in the same position as yourself exept a little less miles (90k). I would say go for it but its one of these things its imperative that you put it in somewhere they know exactly what they are doing. From the research I done I came to the conclusion that if there is problems after a gearbox service its either not been done correctly or the owner has problems before hand and are led to belive a service/flush will cure the box, then the new fluid etc just finishes off the already faulty unit.
21st Feb 2015 1:54pm |
Tell me again Craig, how you "specialise" in these cars?
21st Feb 2015 6:30pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
21st Feb 2015 7:44pm |
Tell me again how this is reckless It takes a trained eye to spot issues with a gearbox before a flush. If there are issues, generally, I walk away unless the customer insists on having it done, regardless of the outcome or consequences The adaptive values SHOULD be reset after an oil change, due to:
I have flushed over 60 ZF 6HP26 boxes now, all without issue. So what am I doing wrong? |
22nd Feb 2015 6:56am |
