![]() | Home > Technical (L322) > Clunky changedown after full service (inc gearbox service). |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Yours is the 6sp sir |
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 ![]() ![]() |
Many thanks, Craig, |
Ok. I have decided to take my car to Guy Salmon at Knutsford to have the ATF changed.
I'm afraid dropping the pan and changing 9 litres of oil in your gear box will not do , you would now have a situation where you have two different oils mixing in the gear box . The gear box will now have to be flushed by megaflushing at a specialist and refilled with ZF lifeguard 6 , it won't be cheep because Lifeguard 6 is not cheep but this is now you only course of action after the incompetence of the first garage servicing your gear box with out bothering to find out how .
Thanks, Axle.
Put a request out on here for recommended/trusted companies in your area used by forum members on here |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I can write with some authority on this as I have the T Shirt. A so called "LR Specialist" filled my auto box with industrial bus / coach ATF |
Good thinking Batperson. ![]() |
Very interesting stuff, Skot. PM sent. ![]() |
I'm not a million miles away from RRPhil. I wonder if he would interested in changing my ATF or recommending a man that can? |
Okay, here's a plot thickener if ever there was one.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
Thanks, Pete. |
I used to feel like that about cars.... try and change your point of view...
