Home > Technical (L322) > Rear wash / wiper |
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 |
Mine's the same. A few weeks ago I had the whole lot apart because none of it worked. I fitted a new non return valve hoping it would help but its just the same - it takes a whole wash cycle to prime it
14th Feb 2015 4:05pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
^ snap =crap, so gave up |
14th Feb 2015 4:45pm |
v8rich Member Since: 28 Dec 2013 Location: Healing, Lincolnshire Posts: 67 |
From what I can make out.. A swift push forward on the stalk, and release to start the cycle, it then pumps some water out before moving the wiper (in theory).
14th Feb 2015 5:06pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
The small non return valve in the upper tailgate which fails, only a couple of quids, when it's gone it allows the water to drain back to the reservoir so it has to be pumped all the way back hence the delay.
14th Feb 2015 5:44pm |
Maxmax171 Member Since: 01 Feb 2015 Location: Devon Posts: 9 |
Couple of weeks ago purchase my first l322 (2006 sc, upgrade from the p38 that eventually died) and my rear wash is also the same, pump runs but only get a dribble of water, I think the non return valve may be stuck, can someone tell me the location and how to get to it before I start stripping the wrong bits! Thanks |
15th Feb 2015 9:13am |
Maxmax, mine was blocked up with sediment in the transfer tube - this is fairly common. I managed to clean it out without removing the rear wiper motor just by removing the rear wiper arm and poking some wire down the hole (the transfer tube). Standby for the squirt of filthy water when it goes - it got me a treat.... I was then a bit unlucky in that once flowing it leaked - another common issue but look in the wiki for how to change the little seal if that happens
15th Feb 2015 9:34am |
Thanks will give it a try this week |
15th Feb 2015 11:03am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
there are 'how to's ' in our wiki btw.. ... - .- -.
15th Feb 2015 11:15am |
Thanks Stan, sry should of checked that first |
15th Feb 2015 11:17am |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
Hence why my back window is scratched because of this, |
16th Feb 2015 11:37am |
choplee Member Since: 11 Feb 2015 Location: Kent Posts: 31 |
I thought this may have been cause of leak into the boot for me a faulty non-return valve of bad pipe ,but it seems to be the black 90* turrit on the bottom of the wiper motor housing .... It must be some back pressure pushing water back out of this plastic turrit ..... 57 - Silver TDV8 VSE loaded
16th Feb 2015 9:32pm |
