Home > General (L405) > Outstanding Campaigns
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
My vehicle has now been delivered to the dealer awaiting collection on 1st March.
Topix is showing 2 outstanding campaigns relating to my vehicle...
Does anybody know anything about:
Q454 - Vehicle Wheel Nuts Quality
And
Q465 - RHD Cockpit Harness
Reassuring that a vehicle which just came off the line already has outstanding issues...
If anyone has full Topix access, some more info on the above would be appreciated.
Thanks
Post #312243 11th Feb 2015 9:55pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
I wonder if being able to easily access this sort of information is a good idea, reputationally.
Post #312245 11th Feb 2015 10:16pm
Autobiography
I know what you mean. I can't think of any other manufacturer that makes it so easy.
Must admit it's a bit disappointing to see...cars being built on the line are clearly being built with defects which dealers are expected to fix on PDI or later...
Post #312247 11th Feb 2015 10:36pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
British engineering! Built to standard. Crude but effective sadly.
Post #312395 12th Feb 2015 11:12pm
noworries4x4
More like built to a price If everything is under control you are not going fast enough.
MY 16 Discovery 4 Commercial Workshop and Escort Vehicle
MY 12 Full Fat TDV8
1952 Series 1 80" 3ltr 6cyl
Post #312397 12th Feb 2015 11:21pm
crookedm
100%
The standard being poor.
Post #312398 12th Feb 2015 11:25pm
Autobiography
I'm going to let my retailer know I'm aware to ensure these are done.
Post #312408 13th Feb 2015 5:58am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Understanding the JiT process will help you understand why this happens to some units
Your lucky I have 86 Units with a Safety recall (The worse type Censored)
Post #312409 13th Feb 2015 6:09am
Autobiography
Oh gosh what's the safety recall?
Do you know anything about the two campaigns affecting mine? Big job?
Post #312422 13th Feb 2015 9:02am
GUM97
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
(Hi all, first post here! Been more of a Defender + D4 man in the past!!)
Q465-
Quote:
A potential concern has been identified with the wiring installed into the cockpit harness for right hand drive 2015 model year vehicles in the above VIN range. Vehicles should not be operated using the max cooling function until further notice.
These vehicles can't be released from dealers until LR decide upon a fix for the problem, which does not exist as of yet.
Q454- (Now called P056 as it is a safety recall)
Quote:
A concern has been identified where a number of non-black coloured wheel nuts fitted to certain 2015 Model Year Land Rover Range Rover, Range Rover Sport and Discovery vehicles may not be to the correct specification.
Wheel nuts installed on the affected vehicles may have been manufactured from raw material where the ultimate tensile strength is lower than that required. In this condition some wheel nuts may crack and detach from the wheel hub stud when subjected to shock loading.
In the event of there being 2 or more wheel nuts fitted to a wheel hub where the ultimate tensile strength is lower than required, and the wheel hub has been subjected to shock loading. The remaining wheel nuts may not be sufficiently strong to secure the wheel to the wheel hub.
Wheels may therefore detach, leading to loss of vehicle control which increases the risk of a vehicle crash.
These wheel nuts will be replaced, so a very simple job.
Hope that helps clarify things.
Pete
Post #312755 15th Feb 2015 10:22am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Jeezus I love this write up ^
"Wheels may therefore detach, leading to loss of vehicle control which increases the risk of a vehicle crash"
...increases the risk of a vehicle crash....? Typical paraphrase by a deskrat.
Isn't it shameful to produce a 100+ k car and buy the cheepest wheelnuts you can find?
Post #312781 15th Feb 2015 12:44pm
Philip
Let down by a third-party supplier, it isn't just LR it happens to.
Post #312785 15th Feb 2015 1:00pm
Robert
You're right Trommel, even NASA works that way....
No risk of loosing a wheel but....
Post #312787 15th Feb 2015 1:02pm
Autobiography
Looks like my vehicle is going to be stuck with Land Rover then. Not too keen on the sound of that wiring harness one.
Thanks so much for the info and welcome to the forum.
Post #312809 15th Feb 2015 3:25pm
Autobiography
Third campaign now appeared affecting the vehicle.
Q455 - Incorrect Diesel Fuel Filler Neck Fitted
Should I be concerned we have a lemon on our hands?
Post #313278 17th Feb 2015 4:10pm
