Home > Technical (L322) > HEATED STEERING WHEEL L322 VOGUE
Page 2 of 3 <123>
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
yes i will try that, thanks
bob
Post #311575 8th Feb 2015 5:54pm
Not that much for a new wheel....
http://www.powerfuluk.com/products/range-r...overs.html
And they look so much better as well..
Old one
New one
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #311589 8th Feb 2015 6:32pm
miggit
The steering wheel switch is non latching, and if the red light is coming on then the switch is doing its job. But if the light is going out almost instantly, I would surspect the 'ECU' Laughing it's a timer circuit, the names that they give to these items is a joke, anyway the timer on mine stays on for about 30 minutes and then turns its self off. If yours' is going out after a few seconds, I would suspect that it's lost it's count on the chip and is just going to the off straight away.
If your going to pull the steering wheel apart it would be an idea to put a multi meter on the steering wheel connections just to make sure that there is still a cuircut. Yesterday I couldn't spell Engineer... Today I are one!
Post #311686 8th Feb 2015 11:37pm
Cam-Tech-Craig wrote:
There is an ECU box in the steering wheel behind the Airbag... Probably unserviceable sir Neutral
As i said Miggit Thumbs Up
Post #311687 8th Feb 2015 11:38pm
miggit
Are But Craig its not an ECU it's a bloody slow glow plug timer Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #311689 8th Feb 2015 11:59pm
Are but its
Electronic.... It
Controls the steering wheel heater and its a
Unit sir Whistle Whistle Whistle
Post #311690 9th Feb 2015 12:06am
miggit
What your saying is it's a re-named glow plug timer that L/R have marked up to the power of 10 Shocked
At first I thought that it might be controled by the tempriture of the steering wheel, but as outside tempritures has no effect on the the time it stays on, I'm now thinking that it's a simple timer with a fancy name Very Happy
On that logic my 1994 Jeep has ECU controled wipers Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #311691 9th Feb 2015 12:20am
Just being facetious Miggit Bow down
Just saying i mentioned it a while ago and seem to be ignored! Rolling Eyes
Post #311692 9th Feb 2015 12:26am
miggit
Wasn't ignoring bud, just questioning the implied computer control bit, a timer chip is more like a stupid computer sitting in the corner with it's shoes and shocks off, to enable it to count to 20! ECU's to me contain a processor and require mutiple inputs to function, where as we are talking about something that's more like a flasher unit or a wiper delay relay. Relay to me is £5 to £30, ECU is £200 plus, although if JLR are invloved £200 + for a simple relay is not beyond imagination Laughing
Have you seen the RRP on the dash ends, going back to your cup holder mod, if they can price a piece of plastic at over £1100 Shocked How much for a simple timer ? Yesterday I couldn't spell Engineer... Today I are one!
Post #311693 9th Feb 2015 12:40am
Miggit, di you remember the Austin Meastro Whistle Whistle Whistle
They had ECU's Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up
Post #311697 9th Feb 2015 1:18am
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Sounds like the element has developed a fault. I had the exact same problem. Press the button, red light comes on then goes off. Is a circuit that's constantly monitored by a thermistor used to regulate the temperature, same as the heated seats. The eminent could be fine and the thermistor could be at fault. Regardless no items are serviceable. The wheel change is an easy job although the air bag is fiddly to remove (especially if someone's been at it before)
A new wheel, or working 2nd hand one will solve your problem. You can't have a RR without a working heated wheel, it's the law!
Post #311709 9th Feb 2015 7:48am
miggit
Craig Shocked Shocked That'll be the wiper delay then Wink Rolling with laughter Rolling with laughter , athough it might be the fancy illuminated columb stalks that they are refering to, not even L/R fit them Wink
It all started as advertising hype in the states in the 50's / 60's, they thought that calling things o-matic or o-tronic, it made them more up to date and desireable. My '66 Thunderbird was fitted with a Cruise-o-matic gearbox Bow down , until you find out that it's only a 2 speed Shocked . Fortuneatly mine is an export model which ended up with the boring standard C6 automatic transmission, which has more gears and takes more power Smile
My wheel fittng guides are a pee take hommarge to this, that's why I called them the Guide-o-Matic, Censored Censored didn't work, maybe should called them a Wheel GCU Laughing
SteveyD were you able to check the old wheel, or did you just take a chance that it was the element / thermistor? Yesterday I couldn't spell Engineer... Today I are one!
Post #311711 9th Feb 2015 8:34am
Well my steering wheel ECU must be well broken because mine stays on for as long as the button is pressed, had it on for three hours the other day.... I do like warm fingers....
Mind you I do moan that the stitched seam doesn't get quite as hot as the rest of the wheel.... never bl00dy satisfied as SWMBO keeps reminding me.... Pete
Post #311784 9th Feb 2015 3:01pm
miggit
Shocked Shocked 3 Hours Shocked Shocked
That would point at mine being on it's way to being fubard Sad Does anyone elses stay on for hours ?
Mine doesn't get that hot, would say it's warm, and nowhere near the level of the seats. Yesterday I couldn't spell Engineer... Today I are one!
Post #311801 9th Feb 2015 6:44pm
Mine never self switches off! Once turned on, it stays on until either i turn it off or i finish my journey!
Mine doesn't get HOT! Warm yes but NOT HOT! (Overfinch wheel with OE JLR control module)
Post #311803 9th Feb 2015 6:50pm
Page 2 of 3 <123>
