![]() | Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
surely a heat gun would be a better and safer option... ... - .- -.
^^ Wot he said |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Right! I finally did mine today. I should have placed the lamps in a bowl of hot water as suggested before using the hairdryer to soften the glue. It took me over 40 mins to separate each lamp before checking how the LED's would fit.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Well done that man |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
nice job but looks like you could have went with a lot bigger LED board to fill up the area for even more light.
how was the lens stuck back onto the unit? ... - .- -.
I haven't done it yet, but I think that Scottyav used clear silicone to fix his, I did experiment with solvent weld on a rear light, that sort of worked. But I'm leaning towards some epoxy resin glue to refix mine, I would use polyflex or sikaflex, but they don't do it in clear |
I fixed my LED's to the reflector using superglue and a couple of dabs of sealant.
Just done mine over the last 24 hours, and have just used them in anger |
thanks paul... |
No problems Stan, as long as you take your time splitting them they will part cleanly, and remember that that Epoxy Resin is a |
i think i'm a compulsive led buyer as i have a stash of smd and cob panels bought of ebay |
v8rich Member Since: 28 Dec 2013 Location: Healing, Lincolnshire Posts: 67 ![]() ![]() ![]() |
Halfway through fitting these ones to mine:
