Home > Technical (L322) > 3.6 TDV8 EGR options? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
Alive Tuning, for one can map out TDV8 EGRs If you are familiar with mapping software, it's not a huge issue to overcome. The issues lie I making sure your work is not copied by Joe Bloggs |
20th Nov 2014 6:37pm |
Bit more complex on the TDV8
21st Nov 2014 8:52am |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
Mikey
21st Nov 2014 11:58am |
No. A warning light does not a complex system make. And emissions tightening standards is only sensible.
21st Nov 2014 1:27pm |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 |
On the point of blanking the EGR with plates, we have done this in a few local TDV8 3.6 without deleting the EGR duty cycle in the map, and have had no DTC come up
16th Jan 2015 10:31pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
So, does mapping out the EGR valves cause emission problems at MOT time? Got - 2017 SDV8 Autobiography in Loire Blue
16th Jan 2015 10:55pm |
We don't have such a thing as an MOT here in Africa
17th Jan 2015 12:37am |
No, just to the thread Got - 2017 SDV8 Autobiography in Loire Blue
17th Jan 2015 12:58am |
Yes Yes Yes.......someone who thinks like me, if you blank the port on the inlet side of the valve the actual valve would open (ecu's doing its thing valves opening ecu thinks everything is ok) but the burnt gas is not returning to the inlet chamber..........as to UK and ROW cars after exploring the CCF on a UK car everything is there to change it to a AU configuration on the audio and TV side of things any way the venture cam was also there but turned off all you have to do to get it working on a car that came out of the factory without one is turn it on in the CCF, so I would guess there is no difference in the programs only in the way they are set up Did you notice any improvement after blanking them off?? In respect of the MOT I would say not if the motors ruining well it will pass an emissions test with the EGR blanked Ziggy "Those who cannot remember the past are condemned to repeat it." George Santayana Puts away his cloth cap and donkey jacket Goes and sits in the naughty corner |
17th Jan 2015 1:13am |
My D3 passed its latest MOT with no EGRs and with no Cat |
17th Jan 2015 9:05am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Bet that smells like an old ice cream van doesn't it? Removing both the EGR & Cat makes them stink! |
17th Jan 2015 9:15am |
It doesn't smell nice
17th Jan 2015 9:29am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
Over to you Craig yours takes some beating |
17th Jan 2015 10:51am |
Mikey is referring to a 2.7 tdv6 Disco Scott... So no comparison to a tdv8 FF my friend... |
17th Jan 2015 11:46am |
