Home > Technical (L322) > 3.6 TDV8 EGR options?
Page 1 of 5 12345>
NickH72
Hi all ,
Apparently the intermittent engine light is my EGR valves need replacing.. not closing when they should?
Been quoted £1000... ouch!
Can you remove or block them on this engine or is there a way to make them work again without paying that amount! ???
I have seen via old google that you can delete them altogether so there are no codes and they stay shut!?
Thanks
Nick
Post #274841 7th Aug 2014 6:12pm
Mikey
They can be mapped out, with the appropriate software Thumbs Up
Post #274844 7th Aug 2014 6:26pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Yup, I got a Viezu v-box for my s class and they mapped out the egr. You get two maps and a code reader for £400ish
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #274901 7th Aug 2014 10:27pm
Sounds quite steep!
I saw some egr cleaner in halfords the other day, wonder if that would help. Not used it myself, but the theory sounds ok, spray it into the intake and it cleans out the gunk. There is nothing that can't be fixed with a hammer😜😜
Post #274902 7th Aug 2014 10:36pm
I looked into this and was told that the EGR valves definitely couldn't be blocked? Question Got - 2017 SDV8 Autobiography in Loire Blue
Post #274916 8th Aug 2014 12:34am
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Have a chat with gary @ Alive Tuning - he's managed to map them shut ... Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #274925 8th Aug 2014 7:31am
Mikey
northernmonkeyjones wrote:
Sounds quite steep!
Would love to know how these sprays repair these little roller bearings
Post #274926 8th Aug 2014 7:36am
Re: 3.6 TDV8 EGR options?
NickH72 wrote:
Hi all ,
Apparently the intermittent engine light is my EGR valves need replacing.. not closing when they should?".............
Nick, bite the bullet and get them done before you overspeed one of your Turbo's! This will usually result in the Turbo failing very soon after the EGR is replaced, often destroying your engine! This is fact sir!!! Thumbs Up
Post #274927 8th Aug 2014 8:19am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
craig, if the EGR is blanked out or mapped out will it be detrimental to the turbo?
thanks
raj 2011 4.4 TdV8 Nara Bronze
Post #274946 8th Aug 2014 12:10pm
NickH72
Hi Craig,
thanks... so if they are stuck open this will happen? or if I replace them it could kill the turbo? sorry, for being a div!
The light came on and since the diagnosis it hasn't re appeared!
Thanks
Nick
Post #274956 8th Aug 2014 2:49pm
Mikey
Would love to hear the theory behind this too...
Post #274969 8th Aug 2014 5:14pm
TheAllSeeingPie
The EGR allows a small amount if exhaust gas into the engine under certain circumstances. This is usually when the engine is hot and not under significant load. The added exhaust gas essentially reduces the effective amount of oxygen, which in turn can be thought of making a 3.6 into a 1.6 temporarily. This is good for emissions too as having the exhaust gas become part of the combustion again reduces Nox emissions. Disabling the EGR has no detriment to the engine as it's an emissions device and isn't used 100% of the time.
The problem is when the EGR is left open and you start putting load on the engine. The increased exhaust flow is routed back into the engine which increases the exhaust temp which then melts important things in the engine like turbo seals and the turbo itself, which is expensive, or even worse heats up your engine oil (turbos are oil cooled) and melts things inside the engine which is even more expensive.
Map it out and your engine will run cooler and it sometimes reduces turbo lag when overtaking, although this depends on how good your EGR system is in the first place. More benefit is had from disabling crude EGRs.
As for using some EGR cleaner, that might work in you have a small smattering of soot on your EGR, but by time most people have noticed degraded EGRs they will have had unburnt diesel, soot and anything else the air filter missed baked onto the EGR by 1200 degree exhaust gases. The only thing I've ever managed to use to clean an EGR is a bucket of petrol, 48 hours soaking and then an hour or two of wire brushing.
Post #275062 9th Aug 2014 9:55am
TheAllSeeingPie
You can't block them as the ECU will still attempt to activate them. Instead removing the duty cycle from the ECU and it'll never attempt to monitor or open and close it.
Post #275063 9th Aug 2014 9:57am
Stephen.Gazard
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
NickH72 wrote:
Hi all ,
Craig is speaking from experience there ..... just happened to mine which Craig has been fixing my broken engine .... Stephen Gazard
Range Rover L405 LWB SVA Overfinch / Bespoke
Maserati GT 2017
Maserati Levante Trofeo
Mercedes SL63 AMG
Mercedes S500L
Post #275120 9th Aug 2014 9:46pm
goldsax
i had no idea re.the full function of the EGR.
thanks for the info
Post #275125 9th Aug 2014 10:58pm
Page 1 of 5 12345>
