Home > Technical (L322) > Help!! No reverse!! I'm on holiday....will I drive FF home?? |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
Oh and what might be of interest to those who know about this problem: since some 2 months when selecting reverse the is some 2-5 seconds delay before you feel the car taking off.
10th Jan 2015 8:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 |
i have no idea what is wrong but hopefully someone will come along and advise but i think you have a big problem... ... - .- -.
10th Jan 2015 9:13pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8354 |
I'd get the fluid level checked, maybe low on oil.... Pete
10th Jan 2015 9:18pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 |
Could be that the linkage needs greasing, causes the same symptoms on the zf box. Not sure about gm box though.
10th Jan 2015 9:22pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Pete was bang on the money... Sounds low on fluid to me... Probably has a leak and driving it low on oil will probably kill the box sir
10th Jan 2015 9:35pm |
11th Jan 2015 7:13am |
NO! But its the best, easiest and simplest place to start my friend... IMHO the linkage would need checking too, because if the gearbox is selecting reverse but the selector does not know its in reverse then that also could be the issue...
11th Jan 2015 8:08am |
@Cam-tech-craig; just checked the fluid at 42 degr. C (always have my IIDTool with me ) and nothing dripped out. So definitely too low! Nowhere any sign of a leak! Linkage seemed OK.
11th Jan 2015 5:13pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 |
Had a similar problem a couple of years back with reverse only and it was a crack in the valve block. Fluid pressure was lost in reverse, all forward gears were ok. Engine was revving then reverse went in with a jolt. There was no sign of any fluid leakage either. |
11th Jan 2015 7:47pm |
fingers crossed for you pal |
11th Jan 2015 11:02pm |
Thnks! Cam-tech-craig!
12th Jan 2015 7:33am |
No, mine is a 4.4 V8 petrol. |
12th Jan 2015 7:46am |
Hey you guys, guess what... went to the pharmacist to buy a syringe for injecting the fluid into the filler hole. Was a very helpful guy thinking of what else may work out. He suggested to use a rectal iirigator and yes he is right: nice long tube, tap at the injector side and a wide funnel at the other side. Think this must work out fine . Fluid is expected to arrive at Friday. Keep you informed about proceedings. |
13th Jan 2015 5:46pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Did you have to buy one, or did you already have one? |
13th Jan 2015 6:39pm |
