Home > Technical (L322) > Help!! No reverse!! I'm on holiday....will I drive FF home??
Page 1 of 3 123>
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Help!! Having travelled 1000 km to Italy. Yesterday after arrival and having unpacked the car I came to discover that I had no reverse when driving slightly uphill Big Cry Only very slippery rearward movement when revving up. In Low gear there seemed to be more movement and less slip. Today in the morning I drove the car for 20 min. and after that reverse seemed quite normal (on flat ground). When leaving this afternoon (right after starting up) there was practical no reverse (high and low gear the same) Crying or Very sad . Managed to get out and after 20 min drive there was low gear reverse movement quite normal again (didn't even try high gear).
I need the car every day to get to the ski slopes (at least 10 min drive with some hills). How much harm will this do? And will I be able to drive the car back home next week?
Any help really, really much needed Bow down Bow down Wify is loosing her faith in the car Whistle
Post #304103 10th Jan 2015 8:15pm
Rangie4fun
Oh and what might be of interest to those who know about this problem: since some 2 months when selecting reverse the is some 2-5 seconds delay before you feel the car taking off.
TC on it's way out?
Post #304104 10th Jan 2015 8:17pm
i have no idea what is wrong but hopefully someone will come along and advise but i think you have a big problem... ... - .- -.
Post #304121 10th Jan 2015 9:13pm
I'd get the fluid level checked, maybe low on oil.... Pete
Post #304122 10th Jan 2015 9:18pm
Could be that the linkage needs greasing, causes the same symptoms on the zf box. Not sure about gm box though.
A good squirt of wd and coat of grease sorts this out most of the time on zf There is nothing that can't be fixed with a hammer😜😜
Post #304124 10th Jan 2015 9:22pm
Pete was bang on the money... Sounds low on fluid to me... Probably has a leak and driving it low on oil will probably kill the box sir Rolling Eyes
So, find a local garage that can check the level and also check for a leak! (don't be surprised if a leak is not obvious) BUT make sure they use the correct fluid sir Thumbs Up
Post #304126 10th Jan 2015 9:35pm
Rangie4fun
Bow down Bow down
Thank you for your quick help guys!
@ Cam-tech-graig; is there an explanation for low fluid only affecting the reverse? D seems like normal.
Is there anyone out there who has had the "linkage problem" with the GM box as suggested by Northernmonkeyjones?
Many thanks again!
Post #304159 11th Jan 2015 7:13am
NO! But its the best, easiest and simplest place to start my friend... IMHO the linkage would need checking too, because if the gearbox is selecting reverse but the selector does not know its in reverse then that also could be the issue...
ie... My D2 with an XYZ switch (on the side of the gearbox) if you select D and D does not light up on the gear selector panel BUT the gear lever is in D (but a mm to far or visa versa) will drive away in a default 3rd gear!
Im not sure exactly how the electronics work on a TD6 but it could be similar? Either way, have both the fluid level checked and check when putting the car in D or R it shown it on the displays too Thumbs Up
Post #304162 11th Jan 2015 8:08am
Rangie4fun
@Cam-tech-craig; just checked the fluid at 42 degr. C (always have my IIDTool with me Mr. Green ) and nothing dripped out. So definitely too low! Nowhere any sign of a leak! Linkage seemed OK.
What a shame on me Shocked I did the flush this summer myself. Guess I didn't change enough trough the gears when topping off.
Now going to order the fluid and find a big syringe out here so I can top off properly at the end of the week.
Many thanks Bow down Bow down Bow down and please keep your fingers cross with me that this will solve the problem Smile
Post #304225 11th Jan 2015 5:13pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Had a similar problem a couple of years back with reverse only and it was a crack in the valve block. Fluid pressure was lost in reverse, all forward gears were ok. Engine was revving then reverse went in with a jolt. There was no sign of any fluid leakage either.
Post #304256 11th Jan 2015 7:47pm
Thumbs Up Thumbs Up Thumbs Up fingers crossed for you pal Thumbs Up Thumbs Up Thumbs Up
Post #304303 11th Jan 2015 11:02pm
Rangie4fun
Thnks! Cam-tech-craig! Thumbs Up
@paulTyrer: Thnks for your reassuring post (at least I'm not the only one Rolling Eyes ) You had this problem also with a FF Td6? Mine doesn't seem to be very impressed by revving up Neutral just makes the slip worse Question and definitely no jolt at all. What I experience is that when cold there's hardly any rearward movement at all and when fluid being warmed up (can check this with IIDTool) there's at least any in low gear
Post #304329 12th Jan 2015 7:33am
PaulTyrer
No, mine is a 4.4 V8 petrol.
Post #304330 12th Jan 2015 7:46am
Rangie4fun
Hey you guys, guess what... went to the pharmacist to buy a syringe for injecting the fluid into the filler hole. Was a very helpful guy thinking of what else may work out. He suggested to use a rectal iirigator Rolling with laughter and yes he is right: nice long tube, tap at the injector side and a wide funnel at the other side. Think this must work out fine Whistle . Fluid is expected to arrive at Friday. Keep you informed about proceedings.
Post #304796 13th Jan 2015 5:46pm
Did you have to buy one, or did you already have one?
Post #304806 13th Jan 2015 6:39pm
Page 1 of 3 123>
