![]() | Home > Maintenance & Mods (L322) > Noisy Rear Suspension - sounds like an old spring mattress |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 ![]() ![]() ![]() |
Hi,
A read of these 3 links should get you started bwelton with considerations that include dry joints:
Ive looked through the links but think its different to the 'Pram' condition and I'm not sure about the problems in the 1st two links.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8376 ![]() ![]() ![]() |
Can you get it to do it by rocking the car?? mine had a squeak just like yours which was a rear lower hub joint, you could get it to do it and find it easily on a ramp... Pete
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Sounds like a suspension bush. Mine used to creak like a good 'un on the right rear side when I drove over even small bumps in the road. It also used to creak when I got out. Had it sorted by my local independent for about £80 No longer FF owner but still interested. Present car Jaguar XE
3 hours into a 4 hour drive today and ours started creaking at the front end again. Also when rocking the steering wheel from left to right it sounded like an old suspension style pram or mattress, whatever you want to call it.
Pld118, that sounds like the rack end, it's a nylon ball joint with some grease in the joint, when it wears a lot of the grease goes and whats left then hardens when cold...
Thanks very much for the reply Pete. I commented at the time there might be a nylon/ steering aspect to it. In fact, I'm sure our Discovery3 had this job done a few years ago due to us reporting a nylon rubbing sound when steering lock was applied.
Remove track rod end, counting the number of turns, remove rubber bellows from rack, undo large nut that holds the rack end on, It's pretty big so you will need a large adjustable or similar, remove rack end, put new one on, refit bellows with cable ties and screw track rod end back on the same number of turns...
Thanks very much Pete |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
good luck trying to remove the track rod end.......be amazed if it's not seized......might be as well buying a whole new assembly (just done the same job on my M3) Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
That's what we like... A wee bit of optimism to see out the old and bring in the new!!! |
Changed both on mine in the last year, both very old if not original and had no bother with either..... Pete
