Home > Maintenance & Mods (L322) > Noisy Rear Suspension - sounds like an old spring mattress |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 |
Hi,
25th Dec 2014 9:36pm |
A read of these 3 links should get you started bwelton with considerations that include dry joints:
26th Dec 2014 10:16am |
Ive looked through the links but think its different to the 'Pram' condition and I'm not sure about the problems in the 1st two links.
26th Dec 2014 11:38am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Can you get it to do it by rocking the car?? mine had a squeak just like yours which was a rear lower hub joint, you could get it to do it and find it easily on a ramp... Pete
26th Dec 2014 5:22pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Sounds like a suspension bush. Mine used to creak like a good 'un on the right rear side when I drove over even small bumps in the road. It also used to creak when I got out. Had it sorted by my local independent for about £80 No longer FF owner but still interested. Present car Jaguar XE
28th Dec 2014 6:29pm |
3 hours into a 4 hour drive today and ours started creaking at the front end again. Also when rocking the steering wheel from left to right it sounded like an old suspension style pram or mattress, whatever you want to call it.
28th Dec 2014 9:35pm |
Pld118, that sounds like the rack end, it's a nylon ball joint with some grease in the joint, when it wears a lot of the grease goes and whats left then hardens when cold...
29th Dec 2014 5:37pm |
Thanks very much for the reply Pete. I commented at the time there might be a nylon/ steering aspect to it. In fact, I'm sure our Discovery3 had this job done a few years ago due to us reporting a nylon rubbing sound when steering lock was applied.
29th Dec 2014 5:54pm |
Remove track rod end, counting the number of turns, remove rubber bellows from rack, undo large nut that holds the rack end on, It's pretty big so you will need a large adjustable or similar, remove rack end, put new one on, refit bellows with cable ties and screw track rod end back on the same number of turns...
29th Dec 2014 8:59pm |
Thanks very much Pete |
29th Dec 2014 11:10pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
good luck trying to remove the track rod end.......be amazed if it's not seized......might be as well buying a whole new assembly (just done the same job on my M3) Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
31st Dec 2014 8:54am |
That's what we like... A wee bit of optimism to see out the old and bring in the new!!!
31st Dec 2014 11:02am |
Changed both on mine in the last year, both very old if not original and had no bother with either..... Pete
31st Dec 2014 12:48pm |
