Home > Technical (L322) > RR slow to access USB Flash Drive |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3808 |
Well having a MY 2010, I thought I would fill a 64GB USB Stick with music and insert it in the appropriate orifice to fill my car with all sorts of sounds, well thats difficult for a start so its only about 1/2 full so far but it is slow and also sometimes seems it just won't play some albums at all - although it generally gets there eventually.
28th Dec 2014 6:17pm |
I didn't mention CDs they also work fine although I generally use MP3 for convenience as my old ears can't really appreciate the difference any more, although I have got about 10CDs from Santa. Can't play vinyl any more unless I get the deck from the attic, same with cassettes my deck is also in the attic. Geoff |
28th Dec 2014 6:48pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35328 |
try two levels geoff, album- track.. ... - .- -.
28th Dec 2014 6:50pm |
Thanks Stan will give it a try, only your response, but plenty of interest in the other non technical post - philistines Geoff |
28th Dec 2014 7:47pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Thanks for the tip l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
28th Dec 2014 7:49pm |
Golden Compass just finished on telly so time to have a look at that troublesome flash drive Geoff |
28th Dec 2014 7:54pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
I found (albeit different car) that big USBs took ages to index, went to 2Gb and was fine. Graham
28th Dec 2014 9:21pm |
Moved everything to two levels - no difference - however have read that the Mac puts a lot of invisible stuff on the stick which may cause problems. Windows next stop Geoff |
28th Dec 2014 9:49pm |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Geoff, I've got a fairly aged 8gb PNY stick with a variety of tracks created in the root directory via a Mac. Seems to work fine, so maybe it is the size of your stick (oo-er missus!) that is causing the issue?
29th Dec 2014 10:19am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Geoff it could also be type of stick. I believe the cheaper versions work better the versions without the security. Also stick should be formatted in FAT32. I can run up to 256 gb in the Jag with no issue I would have thought both systems would be similar. Present :2008 TDV8 HSE
29th Dec 2014 11:50am |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
Geoff, try a stick with smaller memory, my 32gb Kingston works fine
30th Dec 2014 12:35pm |
Well I eventually got to the bottom of this problem and it's all down to those tax dodging s at Apple. If you write the stick from OSX a lot of stuff is included which helps the Mac do its thing, trashes, spotlight searches etc and it often keeps copies of files with "._" at the beginning. The Mac just ignores this stuff however the RR doesn't and to say it gets confused is an understatement.
30th Dec 2014 3:54pm |
scotbruce Member Since: 06 Dec 2014 Location: Aberdeen Posts: 39 |
Read with interest, albeit after the fact, as I'm about to do the same in my 2010my RR VSE and was wondering about using a 32GB or smaller because of previous posts. Thanks, Geoff! |
31st Dec 2014 9:44am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Wow... Didn't understand a word of that Geoff... Glad i specialise in JLR computing & not Apple! (typed on his macbook pro ) |
31st Dec 2014 10:21am |
