Home > Technical (L322) > RR slow to access USB Flash Drive
supershuttle
Well having a MY 2010, I thought I would fill a 64GB USB Stick with music and insert it in the appropriate orifice to fill my car with all sorts of sounds, well thats difficult for a start so its only about 1/2 full so far but it is slow and also sometimes seems it just won't play some albums at all - although it generally gets there eventually.
Is there a trick like there is with the CDs (although I've forgot what it is)? I think its a pretty speedy drive Kingston 64GB and the music is three levels down so you would get
Artist > Album > Tracks (all MP3)
Anyone got any thoughts or ideas, iPod and iPhone both work fine in the other slot but that's not the question.
Out of interest has anyone tried a USB hard drive? Geoff
Post #301371 28th Dec 2014 6:17pm
verydisco
I simply use Cds as one cant beat the quality of uncompressed digital music in the Rangie Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #301383 28th Dec 2014 6:35pm
supershuttle
I didn't mention CDs they also work fine although I generally use MP3 for convenience as my old ears can't really appreciate the difference any more, although I have got about 10CDs from Santa. Can't play vinyl any more unless I get the deck from the attic, same with cassettes my deck is also in the attic. Geoff
Post #301384 28th Dec 2014 6:48pm
try two levels geoff, album- track.. ... - .- -.
Post #301385 28th Dec 2014 6:50pm
supershuttle
Thanks Stan will give it a try, only your response, but plenty of interest in the other non technical post - philistines Very Happy Geoff
Post #301408 28th Dec 2014 7:47pm
verydisco
Thanks for the tip Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #301409 28th Dec 2014 7:49pm
supershuttle
Golden Compass just finished on telly so time to have a look at that troublesome flash drive Geoff
Post #301411 28th Dec 2014 7:54pm
A1GSS
I found (albeit different car) that big USBs took ages to index, went to 2Gb and was fine. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #301456 28th Dec 2014 9:21pm
supershuttle
Moved everything to two levels - no difference - however have read that the Mac puts a lot of invisible stuff on the stick which may cause problems. Windows next stop Very Happy Geoff
Post #301473 28th Dec 2014 9:49pm
Andy B
Geoff, I've got a fairly aged 8gb PNY stick with a variety of tracks created in the root directory via a Mac. Seems to work fine, so maybe it is the size of your stick (oo-er missus!) that is causing the issue?
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #301549 29th Dec 2014 10:19am
Googsy
Geoff it could also be type of stick. I believe the cheaper versions work better the versions without the security. Also stick should be formatted in FAT32. I can run up to 256 gb in the Jag with no issue I would have thought both systems would be similar. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #301581 29th Dec 2014 11:50am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Geoff, try a stick with smaller memory, my 32gb Kingston works fine Thumbs Up
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #301808 30th Dec 2014 12:35pm
supershuttle
Well I eventually got to the bottom of this problem and it's all down to those tax dodging Censored s at Apple. If you write the stick from OSX a lot of stuff is included which helps the Mac do its thing, trashes, spotlight searches etc and it often keeps copies of files with "._" at the beginning. The Mac just ignores this stuff however the RR doesn't and to say it gets confused is an understatement.
Two fixes, use Windoze and in control panel set it to show the hidden files and then delete them or use a third party program like MacPaw to delete all the unneeded Censored on ejecting the USB stick.
I now have a full 64gb stick that's fast as. Thumbs Up Geoff
Post #301852 30th Dec 2014 3:54pm
scotbruce
Scotland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Read with interest, albeit after the fact, as I'm about to do the same in my 2010my RR VSE and was wondering about using a 32GB or smaller because of previous posts. Thanks, Geoff!
Post #302012 31st Dec 2014 9:44am
Wow... Didn't understand a word of that Geoff... Glad i specialise in JLR computing & not Apple! Laughing (typed on his macbook pro Whistle Laughing )
Post #302013 31st Dec 2014 10:21am
