![]() | Home > Technical (L322) > How do I know if I have rear locking diff ? |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
I am not an expert in your model year...but
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35509 ![]() ![]() |
according to the WM its 1.2 litres from dry and less when changed... ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8686 ![]() ![]() ![]() |
In I get the padlock even though I haven't got the locking rear diff, as the locking is done by the abs system afaik. You have to get under and have a look👍 though I would hazard a guess you don't have one as it's not a massively common option. There is nothing that can't be fixed with a hammer๐๐
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
Here is a picture of the rear diff. Checked all the 4x4 info and no sign of any padlocks my car does not have terrain response
?. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
The shot angle doesn't show enough for me...
Done a bit more digging and I recon it is the rear locking diff on mines called LR they checked the vin and said it is and also had another good look underneath this time and spotted a wire going into the top of the diff.
found a 8mm allen socket which fits the fill bolt on the rear diff, tried to free of both the fill bolts front was fine but the rear is not for moving don't want to round it so left it for now.
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
i am facing the same drama with rear diff. has a wire going on top of it.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1278 ![]() ![]() ![]() |
I would say that is a vent pipe, not electric wire. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1355 ![]() ![]() |
If you have the e diff you will see the motor on top of it ๐ |
Yes I also feel that it's not e-diff
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3154 ![]() ![]() ![]() |
This is what the locking diff looks like:
Thanks David, that cleared it. |
