Home > Maintenance & Mods (L322) > Lubeguard & Dr Tranny
ebajema
Paul, park the car at an angle with the filler plug higher (driver side UK) then than other side of the gearbox (so on a high curb for example) let the engine run (in park with parking brake on and blocks on the wheels to be safe) and add it.
When the car is level the fluid should just be running out of the filler opening (with the engine running, otherwise it would be pouring out) but with the car leaning to the left that should not happen so you won't lose any ATF when adding these additives. MY 2010 5.0 SC Galway green and sand interior!!
Post #297519 7th Dec 2014 4:13pm
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
Thanks Ebejema will give it a go once I get the car back Cool 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #297817 8th Dec 2014 10:00pm
Eugene, once this is added do you let it self level by opening the filler on flat ground again or have it slightly over filled? Discovery 4 HSE
Post #297829 8th Dec 2014 10:54pm
Adam, i doubt there is much more than an egg cup if you add both additives... If just the "shudder fix" then not much more than a desert spoon full... And in all of those litres, it won't make any difference in volume my friend Thumbs Up
Post #297836 9th Dec 2014 12:45am
ebajema
Like Craig says, it is very little volume you are adding so I would just put it in, close the plug and turn off the engine. MY 2010 5.0 SC Galway green and sand interior!!
Post #297864 9th Dec 2014 8:06am
Would this stuff help with the standard drivetrain shunt on changing down gears? Discovery 4 HSE
Post #297888 9th Dec 2014 10:59am
Paul_H
Added the Dr Tranny today so we'll see how it goes, will be doing a gearbox oil change over the Xmas break at a friends work shop Wink 2005 Range Rover Vogue with Supercharged Accessories
Post #298871 13th Dec 2014 11:53pm
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
where can you buy this additive in the uk
Post #298945 14th Dec 2014 3:32pm
Your better off putting two tubes in a large gearbox.
http://www.ebay.co.uk/itm/2-Tubes-Dr-Trann...2c9175fbfe
Post #298948 14th Dec 2014 4:06pm
Paul_H
Well I have done about 300 miles since I put the Dr Tranny additive in the gearbox, changes seem smoother and have noticed there is no clunk when putting it in reverse Cool 2005 Range Rover Vogue with Supercharged Accessories
Post #299282 16th Dec 2014 11:43am
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Dr Tranny has sorted mine a treat, their looking to add this to all recon'd ZF boxes due to the rebuiled
Post #299733 18th Dec 2014 8:16pm
ebajema
It's ordered, thanks NFDI for the link Smile. MY 2010 5.0 SC Galway green and sand interior!!
Post #299766 19th Dec 2014 12:35am
On the D3/D4 forum they add Dr Tranny via the front Gearbox Oil Cooler in minutes, can you access the TDV8 Oil Cooler or is it hidden and inaccessible. ?
Post #413479 14th Nov 2016 10:14am
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Gary.
I didn't locate the oil cooler on the TDV8, I just added it to the gearbox when I did the oil/filter change.
Always use the Lubeguard as a preventative/care addition when I do the gearbox maintenance.he last
Have done so for the last 10 years or so, with no problems.
@Phil. Whats your view on these additives?
BTW the motor is still running fine after nearly a year.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #413634 14th Nov 2016 10:09pm
