Home > Maintenance & Mods (L322) > Lubeguard & Dr Tranny |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 |
Thanks Ebejema will give it a go once I get the car back 2005 Range Rover Vogue with Supercharged Accessories
8th Dec 2014 10:00pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6369 |
Eugene, once this is added do you let it self level by opening the filler on flat ground again or have it slightly over filled? Discovery 4 HSE
8th Dec 2014 10:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Adam, i doubt there is much more than an egg cup if you add both additives... If just the "shudder fix" then not much more than a desert spoon full... And in all of those litres, it won't make any difference in volume my friend |
9th Dec 2014 12:45am |
Like Craig says, it is very little volume you are adding so I would just put it in, close the plug and turn off the engine. MY 2010 5.0 SC Galway green and sand interior!!
9th Dec 2014 8:06am |
Would this stuff help with the standard drivetrain shunt on changing down gears? Discovery 4 HSE
9th Dec 2014 10:59am |
Added the Dr Tranny today so we'll see how it goes, will be doing a gearbox oil change over the Xmas break at a friends work shop 2005 Range Rover Vogue with Supercharged Accessories
13th Dec 2014 11:53pm |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
where can you buy this additive in the uk |
14th Dec 2014 3:32pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3976 |
Your better off putting two tubes in a large gearbox.
14th Dec 2014 4:06pm |
Well I have done about 300 miles since I put the Dr Tranny additive in the gearbox, changes seem smoother and have noticed there is no clunk when putting it in reverse 2005 Range Rover Vogue with Supercharged Accessories
16th Dec 2014 11:43am |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
Dr Tranny has sorted mine a treat, their looking to add this to all recon'd ZF boxes due to the rebuiled |
18th Dec 2014 8:16pm |
It's ordered, thanks NFDI for the link . MY 2010 5.0 SC Galway green and sand interior!!
19th Dec 2014 12:35am |
On the D3/D4 forum they add Dr Tranny via the front Gearbox Oil Cooler in minutes, can you access the TDV8 Oil Cooler or is it hidden and inaccessible. ? |
14th Nov 2016 10:14am |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Gary.
14th Nov 2016 10:09pm |
