Home > Technical (L322) > Headlights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
the headlight has to be taken off the FF to change any bulbs in the unit, very easy to do but make sure you have a cloth or something on the bumper as it can get scratched... ... - .- -.
18th Nov 2014 4:33pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
New bulbs IN. Didn't take out the headlight to fit the xenon and the full beam light. Much brighter, more coverage on the road too. We checked the alignment of the light before changing bulbs and it was spot on. We looked at the throw of the light and it started off initially bright and went slightly dim after 5-10 secs. Replaced the xenon and checked again, the light started of quite bright and then got brighter over 5-10 secs and again it was spot on on the alignment. The new H7's made a great difference over the bulbs that were in.
18th Nov 2014 6:35pm |
nice one Lad
18th Nov 2014 8:17pm |
Hard to say Stan, in my case there was a big improvement but my original bulbs weren't that good. They are a lot brighter. The ones I put in the D3 weren't these bulbs and I think these are brighter than the ones in the D3. Full beam is A LOT better.
18th Nov 2014 10:49pm |
mine are fine but xmas is coming and i need to ask santa for something ... - .- -.
19th Nov 2014 6:34am |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 |
Lad
19th Nov 2014 9:45am |
Seabass Member Since: 05 Feb 2014 Location: Värmland Posts: 88 |
I've been wanting better lights since I got my FF, after reading this I've ordered these and I hope they will improve the output on mine aswell 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
19th Nov 2014 1:03pm |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Off on a slight tangent, the standard dip beam headlights on the MGTF were .
19th Nov 2014 1:48pm |
one further question men, which is the bulb that is used when normal night driving i.e. NOT on main beam as i find that the normal lights are the ones that are a bit poor.... |
20th Nov 2014 1:12pm |
you have a xenon bulb which is active on dipped beam , when you flick the high beam on there's a little flap that 'opens' up that same bulb to high beam, also the h7 halogens come into play ... ... - .- -.
20th Nov 2014 3:38pm |
ah so its the same bulb for main beam and high beam and those bulbs are the ones at £90 a pop.... gotcha
20th Nov 2014 4:13pm |
only the philips extremes are around that price , you can get decent 6000k ones for about £30 a pair on ebay..
20th Nov 2014 4:52pm |
We're they significantly better than the original ones? As I don't rate mine at all.... I almost want to drive all the time on high beam |
20th Nov 2014 10:13pm |
technically the 4300k temperature is brighter than the 6000k but these were whiter light so it gave the impression of being brighter...
20th Nov 2014 10:18pm |
