Home > Technical (L322) > Headlights
Page 4 of 5 <12345>
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Andy I got the bulbs from hids4u a sponsor on the D3 site. The xenon link is this un
http://www.hids4u.co.uk/philips-d3s-x-trem...-bulb.html
And the high beam link is this un
http://www.hids4u.co.uk/h7-philips-x-treme...-pair.html
I was thinking of getting the 65w ones but didn't want to overload the electrics. Ie, keep it safe Thumbs Up
SWMBO even commented that the bulbs were a vast improvement, that was normal dipped beam. Didn't see high beam.
Post #294485 21st Nov 2014 12:10am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Lad so you changed two bulbs in the end, main headlights and side lights?
stan i like the idea of cranking them up, how easy is that to do?
i looked at how the lights come out? just looks like two screws holding them in at the front when the bonnet is up?
andy
Post #294496 21st Nov 2014 9:32am
Lad
Andy, I changed the main beam and xenon headlight. The sidelights I have are the fairy light LED dot kind. The main beam and xenon were changed without taking the headlight unit out of the car.
Post #294497 21st Nov 2014 9:36am
cant remember how to get the headlight out on the td6 but my SC has 2 on top and 1 hidden underneath the headlight unit, ..as for the beam adjustment there are 2 plastic hex sockets that take an allen key, one is for vertical and the other for horizontal....
i parked in front on the garage ,switched on the headlights and marked the garage door with some black tape and then adjusted ...
when adjusting, if you dont have a fixed focal point you tend to loose where the beams originally were.. ... - .- -.
Post #294498 21st Nov 2014 9:46am
also Andy, i think you might have to take the side indicator unit off first before the headlight, hopefully someone will confirm that or not.. ... - .- -.
Post #294515 21st Nov 2014 11:13am
You don't need to take out the headlights to change the Xenon bulbs on a TD6, procedure as below.
Post #294523 21st Nov 2014 11:39am
nice one David, i couldnt remember how i did mine back in my tractor days. Mr. Green
@Andy, just another point, make sure you get the correct bulbs for yours as the D3S Lad got are for 2010my onwards.. ... - .- -.
Post #294541 21st Nov 2014 1:44pm
Discotigger
@Andyleeds, the bulbs you need are the D2S, there are plenty on ebay.
These are the ones I got for my TD6, a 2005 model Vogue, look really good and give a crisp white light.
Linky.. http://www.ebay.co.uk/itm/2X-LAND-ROVER-RA..._683wt_958
Make sure the ones you get have the anti vibration clasps around the base of the bulb, the little silver clasps you will see in the picture of the bulb. It ensures that they don't fail prematurely. Thumbs Up
Post #294545 21st Nov 2014 2:00pm
Stan, Andy has the same lights as your car sir Thumbs Up
We face lifted it a while ago now from the old square type lights to 06-09 style Thumbs Up
Post #294552 21st Nov 2014 2:35pm
thanks Craig , i looked in his gallery and saw the square shape headlight...
@Andy, you need D1S bulbs and the units do come out, 2 screws at the top and 1 hidden underneath..i dont think you can get your hand inside the unit whilst on the FF unless you have very lady type hands...
headlight adjust is as per pic,
Post #294553 21st Nov 2014 2:40pm
Post #294555 21st Nov 2014 2:47pm
andyleeds
As usual the forum is coming up trumps!
So to summarise I need the D1S bulbs not the D3S type?
This would be handy as they are cheaper too!
And just follow the instructions that nice day has kindly found for me.....
Post #294561 21st Nov 2014 3:19pm
andyleeds
I think I am getting confused
My lights are 2006 version to 2009? So this means D1S? As D3S is for 2009 onwards correct?
Post #294564 21st Nov 2014 3:24pm
you need D1S bulbs, headlight out and change bulb like this,
all in the WM Andy.. ... - .- -.
Post #294565 21st Nov 2014 3:27pm
Discotigger
Sorry Andyleeds, hadn't realised you'd had the facelift so ignore my post.
@Craig. Well spotted sir Thumbs Up Bow down
Post #294593 21st Nov 2014 5:03pm
Page 4 of 5 <12345>
