![]() | Home > Technical (L322) > Headlights |
Just to add, teh H7 ones in the high beam unit. Change them out for the Osram 65w ones. These are basically a H9 bulb on an H7 base. Weel over twice as bright. |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Cheers. Might pop two of those in. I'll get those Philips ones, and report back once fitted. |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 964 ![]() ![]() ![]() |
This is very interesting, my normal driving lamps don't seem great what would be good bulbs to upgrade too both normal and main beam? Am assuming that's it straight forward to swap them round? |
Also does anyone know if there is a switch in the headlamp unit when driving abroad? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
yes there is, its up for the UK and lever down for euroland.. ... - .- -.
cheers stan, i thought that the oracle would know |
inside the unit, you take the round plastic access thinghy off.. ... - .- -.
had a very quick look, i have unscrewed the black lid off so that i can see inside but there was no obvious switch? have we any pics anywhere, also if we wanto upgrade the bulbs do they some out the back without takin the unit out?
yours is a 2005 year isnt Andy? ... - .- -.
face lifted though by craig, so has the 2006 lights.... |
should be there, let me see if i can find a pic... ... - .- -.
will it be in the manual? |
yes its in the topix online manual for sure,
....and headlights out to change the bulbs.... ... - .- -.
