![]() | Home > Maintenance & Mods (L322) > MOT/ Failed on brake lines |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
is it not the case that when the car fails its test and you take it elsewhere when the second garage logs onto the system those failures show up - so it'll just fail straight away unless obvious work has taken place |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
NO I don't think they are linked to previous tests, at least that dint didn't happen on mine. I got fail due to headlight washers not working. took it down the road to my local MOT garage, he found a few advisories (rear bushes needing replacing at some point in the future) but passed first time!! |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
The saga will continue then i will get a 2nd opinion on the failures
Rusty brake pipes are a common fault on FFRRs, usually the rear pipes that corrode first followed by the pipes going to the front flexi pipes. It's also false economy not changing the flexi pipes at the same time |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
I had to replace both rears on my Dec 2008 VSE. Started leaking below B pillar area.
Hi everyone,
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
Or Cuprinol ![]() ![]() |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
I'll be passing your way in a couple of weeks Paul, I'll be popping in to see you at this rate.... |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
It is Ronseal that does what it says on the tin.... and I need to get out more
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
At least if you use Cuprinol you wont suffer any wood worm attack |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
I have corrosion on my offside rear pipe and have bought the all in one genuine Land Rover pipe. However, I am still puzzling over how to install this as it has to cross the back axle and at the same time get down a Narrow gap in front of the nearside rear wheel arch before heading along the chassis to the coupling at the front wheel arch.. Has anyone solved this puzzle? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
@ RRBlue
joe,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
If you just keep going from one garage to the next, and to the next, and to the next until they give you the news you want then... Surely your not getting the work done that has clearly been missed in the last "how long?"
