Home > Maintenance & Mods (L322) > MOT/ Failed on brake lines |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
is it not the case that when the car fails its test and you take it elsewhere when the second garage logs onto the system those failures show up - so it'll just fail straight away unless obvious work has taken place |
7th Nov 2014 7:12pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
NO I don't think they are linked to previous tests, at least that dint didn't happen on mine. I got fail due to headlight washers not working. took it down the road to my local MOT garage, he found a few advisories (rear bushes needing replacing at some point in the future) but passed first time!! |
7th Nov 2014 10:08pm |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 |
The saga will continue then i will get a 2nd opinion on the failures
7th Nov 2014 10:16pm |
Rusty brake pipes are a common fault on FFRRs, usually the rear pipes that corrode first followed by the pipes going to the front flexi pipes. It's also false economy not changing the flexi pipes at the same time |
7th Nov 2014 11:34pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
I had to replace both rears on my Dec 2008 VSE. Started leaking below B pillar area.
8th Nov 2014 6:55am |
Hi everyone,
10th Nov 2014 3:34pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
Or Cuprinol |
10th Nov 2014 3:39pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8189 |
I'll be passing your way in a couple of weeks Paul, I'll be popping in to see you at this rate....
10th Nov 2014 5:04pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
It is Ronseal that does what it says on the tin.... and I need to get out more
10th Nov 2014 7:44pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
At least if you use Cuprinol you wont suffer any wood worm attack I'll have to read the tin to see if it covers Tin Worm Yesterday I couldn't spell Engineer... Today I are one!
11th Nov 2014 2:31pm |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
I have corrosion on my offside rear pipe and have bought the all in one genuine Land Rover pipe. However, I am still puzzling over how to install this as it has to cross the back axle and at the same time get down a Narrow gap in front of the nearside rear wheel arch before heading along the chassis to the coupling at the front wheel arch.. Has anyone solved this puzzle? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
11th Nov 2014 4:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
@ RRBlue
11th Nov 2014 5:43pm |
joe,
12th Nov 2014 6:00am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
If you just keep going from one garage to the next, and to the next, and to the next until they give you the news you want then... Surely your not getting the work done that has clearly been missed in the last "how long?"
12th Nov 2014 8:48am |
