![]() | Home > Technical (L322) > Where does this plug behind the headlight control switch go? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8545 ![]() ![]() ![]() |
Looks a bit like the one for the light in the trim under the light switch... maybe wrong though... there are lots of plugs all over the car that don't have a home, same loom for all the cars so they have differences... if everything works don't worry about it.... Pete
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
As Pete said, on the top end Vogue model there is a light above the drivers right knee... Thats the vacinity where that plug is sir |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 ![]() ![]() ![]() |
Many thanks gents for the quick reply....i can now sleep at night....lol
psgk Member Since: 18 May 2011 Location: Chelmsford, Essex, United Kingdom Posts: 47 ![]() ![]() ![]() |
I have read somewhere that the Vogues with the "Foundry Finish" (Silver Grey) trim never had those courtesy lights fitted to the Drivers and Passenger side but they were fitted in vehicles with the other trim options.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
My '02 HSE has the lights |
Be pretty difficult to drill the holes for them, it's a casting and the holes are recessed with fittings cast into them, you could just cut a hole and glue them in or just get later/ different dash ends... They changed 05ish and the later ones are different and won't fit.... Pete
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Do you mean one of these lights ....
Yep that's the one but it's a fairly large hole and I really don't think you could cut it well enough, the edge of it will show as the light is recessed into the panel.... Pete
