Home > Technical (L322) > Where does this plug behind the headlight control switch go?
Zain
Im in the process of putting my dash back together after getting the missing pixels on my cluster fixed but cant seem to find where this white plug (see pics below) behind the headlight control switch goes. Ive had a thorough look around in the dark labyrinth of space with a torch but just cant locate where it should plug into.......does anyone have a clue?
Post #288038 21st Oct 2014 10:18pm
Looks a bit like the one for the light in the trim under the light switch... maybe wrong though... there are lots of plugs all over the car that don't have a home, same loom for all the cars so they have differences... if everything works don't worry about it.... Pete
Post #288041 21st Oct 2014 10:49pm
As Pete said, on the top end Vogue model there is a light above the drivers right knee... Thats the vacinity where that plug is sir Thumbs Up
Post #288042 21st Oct 2014 11:04pm
Zain
Many thanks gents for the quick reply....i can now sleep at night....lol
....and theres me thinking i did have the top end Vogue from circa 2002 but i dont have the light Sad ......so is it just a case of getting the light fitting and plugging it in?
Post #288047 21st Oct 2014 11:18pm
psgk
I have read somewhere that the Vogues with the "Foundry Finish" (Silver Grey) trim never had those courtesy lights fitted to the Drivers and Passenger side but they were fitted in vehicles with the other trim options.
My Vogue MY2002 just has the footwell lights although, again I understand that the wiring was there for the others as part of the loom.
Like you Zain I had thought of buying the light units and then cutting the holes to fit them, but too many other jobs to do first! Peter Kemp
Chelmsford
UNITED KINGDOM
Range Rover Vogue MY2002 4.4l V8
Java Black
Charcoal Trim / Oxford Seats
Colour Coded: Door Handles, All Badging Front and Rear, Bonnet Vent, Foam A-Bar / Nudge Bar
Range Rover Style 11 20'' Wheels
US Spec Front Sidelight / Indicator Light Units / Rear Light Units (MY2005 Style)
Retro Fit Sony / Alpine RES
Various LED Light upgraded Interior / Exterior
Lower Rear Tailgate Gas Strut modification
Post #288104 22nd Oct 2014 12:14pm
My '02 HSE has the lights Wink .
Post #288107 22nd Oct 2014 12:41pm
Be pretty difficult to drill the holes for them, it's a casting and the holes are recessed with fittings cast into them, you could just cut a hole and glue them in or just get later/ different dash ends... They changed 05ish and the later ones are different and won't fit.... Pete
Post #288110 22nd Oct 2014 1:12pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Do you mean one of these lights ....
Post #288331 23rd Oct 2014 2:31pm
Yep that's the one but it's a fairly large hole and I really don't think you could cut it well enough, the edge of it will show as the light is recessed into the panel.... Pete
Post #288336 23rd Oct 2014 2:34pm
