Home > General > need some advice, sell it and cut my losses or continue... |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
If it is numbers then for example there is this ( although I have blown a few head gaskets on v8's and never had one that runs well ???) http://www.autotrader.co.uk/classified/adv...?logcode=p
9th Oct 2014 4:47pm |
James4287 Member Since: 08 Jun 2014 Location: Cornwall Posts: 20 |
5k with head gasket gone, is he ?!
9th Oct 2014 6:47pm |
Might be worth putting one of these over the expansion tank to see if there is any exhaust in the coolant
9th Oct 2014 7:14pm |
Also I had a p38 which used a load of coolant thought head gasket but it too ran smooth for too long eventually found a leak on the rad where the top tank was crimped it only leaked under pressure so of course evaporated and left no trace I foundd it using dye did the sniff test to confirm it had no slipped liner plus stick a comp test on it - can't remember if you said you had .
9th Oct 2014 7:20pm |
A bit of an old thread here, but some company's may still be going !
9th Oct 2014 7:29pm |
Reconditioned in stock here ; BUT DONT USE, SEE NEXT POST
9th Oct 2014 7:32pm |
Could be a useful read and a company to stay away from
9th Oct 2014 7:42pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Do not, whatever you do use 1st Choice Engines, only ever heard bad about them, if you google them they have terrible reviews as well...
9th Oct 2014 7:50pm |
So that's at least 2 companies to stay away from then......
9th Oct 2014 7:57pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Could be worth just getting the coolant system pressure tested. Find someone with one of these
9th Oct 2014 9:18pm |
If you can't see it leaking out then it's getting into the oil or the pistons.... Pete
9th Oct 2014 9:23pm |
Todays developments in the ongoing saga...
10th Oct 2014 6:38pm |
Is the heater nice and hot, could be an airlock in the system, did you pressure test it hot or cold?? Pete
10th Oct 2014 6:55pm |
Ok my experience of this is with a p38 v8 with lpg the vaporiser is usually two chambers with a neoprene gasket between them to at least there is an area where the gasket prevents water from entering the chamber with the gas. I took mine off and stripped it down - there are a couple of people on fleabay who sell kits to refurb the vaporisers. It was only after I had done all this that I found out that they need doing approx every 7/8 years max so it is worth disconnecting the coolant from the vaporiser and by passing it then retest. |
10th Oct 2014 7:01pm |
