![]() | Home > Technical (L322) > Suspension squeeking? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
Mine does that when the weather has been dry for ages. I recon it's the bushes on the rear suspension squeaking which makes it sound like an old pram.
winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 135 ![]() ![]() |
Ive noticed it doesn't do it when it wet? |
I'm guessing the rubber bush is twisting and squeaking. Cover them in wd40 or such like.
Not advisable to spray WD40 on rubber bushes as it can cause the rubber to break down |
You'll have to go with the "or such like" option then.
WD-40 Specialist Anti Friction Dry PTFE Lubricant 250ml spray can
Yes, that was obviously the wd40 I meant..... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8543 ![]() ![]() ![]() |
Washing up liquid is FULL of salt to soften the water, don't get it anywhere near an FF, they rust well enough on their own.... Pete
OK, I'm gonna have to work harder to cover this one up...... |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Keep a small stash just in case |
Mark, I think what you meant was you use washing up liquid to wash your hands after you haven't used WD40... Pete
Yes, is that not what got posted ? Piggin ipad changed all the spelling and words and context and seems to have become self aware !
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1559 ![]() ![]() |
Did anyone find a definitive cause for the squeak?
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
I've been there (and may end up there again)!
