Home > Technical (L322) > Suspension squeeking?
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
Just noticed when driving with my window down there are some squeaky noises coming from suspension when driving
Any ideas what that could be?
Its a 2005 4.2 Supercharged vogue
cheers
Post #281087 15th Sep 2014 11:17am
mjdronfield
Mine does that when the weather has been dry for ages. I recon it's the bushes on the rear suspension squeaking which makes it sound like an old pram.
I normally cure it by taking it up some grass bank and making the suspension move more that it would under normal conditions ie more articulation. Fine after that for a few months.
That said, it could be something else......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #281089 15th Sep 2014 11:26am
winslo
Ive noticed it doesn't do it when it wet?
Post #281090 15th Sep 2014 11:26am
mjdronfield
I'm guessing the rubber bush is twisting and squeaking. Cover them in wd40 or such like.
Will then see if that's it.
When it's wet prob not as much friction, so no noise..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #281092 15th Sep 2014 11:30am
Not advisable to spray WD40 on rubber bushes as it can cause the rubber to break down
Post #281093 15th Sep 2014 11:36am
mjdronfield
You'll have to go with the "or such like" option then.
What about washing up liquid ?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #281095 15th Sep 2014 11:44am
pld118
WD-40 Specialist Anti Friction Dry PTFE Lubricant 250ml spray can
This product is £3.99 and is designed to be safe on rubber, plastic and other materials/ components and is a product I've used recently because it specifically states on the rear of the tin that it is designed to reduce friction and wear on components including "bushings".
http://www.halfords.com/motoring/engine-oi...cant-250ml
Post #281098 15th Sep 2014 12:00pm
mjdronfield
Yes, that was obviously the wd40 I meant..... Rolling with laughter
Well saved Mark, I don't think anyone has noticed...... Laughing
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #281099 15th Sep 2014 12:04pm
Washing up liquid is FULL of salt to soften the water, don't get it anywhere near an FF, they rust well enough on their own.... Pete
Post #281119 15th Sep 2014 2:01pm
mjdronfield
OK, I'm gonna have to work harder to cover this one up...... Laughing
I will stick to my small axle twister solution.
Has worked so far.
Lubrication advice is best left to others..........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #281123 15th Sep 2014 2:49pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Keep a small stash just in case Whistle Ooops Off Topic
 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #281145 15th Sep 2014 3:59pm
Mark, I think what you meant was you use washing up liquid to wash your hands after you haven't used WD40... Pete
Post #281171 15th Sep 2014 5:15pm
mjdronfield
Yes, is that not what got posted ? Piggin ipad changed all the spelling and words and context and seems to have become self aware !
Laughing
I use expensive car washing shampoo to wash my hands after not using wd40 Whistle
Seriously though, I think a few have the squeaking issue if the suspension moves to an angle it's not been to very often. Perhaps the rubber becomes more rigid over time and is less pliable when required. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #281180 15th Sep 2014 5:30pm
p38arover
Australia
Did anyone find a definitive cause for the squeak?
Mine has just started squeaking from both sides at the rear. I can get it to squeak by just rocking the car. It sounds terrible as I drive through the supermarket car park and over the speed humps.
I hope to get the L322 onto a mate's hoist next week so will hunt about then. If silicone spray is a cure, I'll buy a can before then. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #459662 5th Dec 2017 11:06am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I've been there (and may end up there again)!
It might be the sub frame bushes (http://www.fullfatrr.com/forum/topic21092.html), or it could be the rear suspension hub bushes (http://www.fullfatrr.com/forum/post140711.html) or lastly (and cheapest to check/fix) it could be the handbrake cable rubbing against the chassis (http://www.fullfatrr.com/forum/topic30397.html) - I changed the grommet, added some tubing around the worn cable and it's been quiet since then.
Hope it's the handbrake cable problem for you too!
Post #459667 5th Dec 2017 12:08pm
