Home > Technical (L322) > Suspension squeeking?
chubbs358
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Squeak on mine turned out to be a bit of the underside heat shield. Was under the car having a poke about for no particular reason one day (as you do) and my foot foot accidentally found the squeaky bit it just needed a bit of a tweek to stop it. Shame my gearbox couldn't have been fixed that easily Rolling Eyes 05 Range Rover SC
Previous:
02 fiesta 1.4 zetec (less reliable than a Range Rover)
1998 Audi S4
1991 fiesta rs turbo
1990 1.0 fiesta bonus (the bonus was it was so basic there was nothing to break
1989 fiesta 1.2
David brown 990 selectimatic
Bedford rascal pickup
And some other random nonsense
Post #459734 5th Dec 2017 9:18pm
Sandyt
On my P38 after being in middle east came home to find a family of mice in the bonnet insulation - they squeak Laughing
Post #459744 5th Dec 2017 9:55pm
p38arover
Australia
VaguelyVogue wrote:
I've been there (and may end up there again)!
Thanks VV. I'll check those things when it's on the hoist.
I'll check the heat shield, Chubbs. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #459772 5th Dec 2017 11:44pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
My right rear was squeaking. It is embarrassing driving through the town Suspension bushes as mentioned dry out a bit then squeak. Lube them up and buy a bit more time but eventually replacement is needed. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #459780 6th Dec 2017 12:02am
p38arover
Australia
I found this on RRNET. See the last post on page 1 by Haylands: http://www.rangerovers.net/forum/6-range-r...e-tia.html Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #460104 9th Dec 2017 11:49am
p38arover
Australia
A friend and I replaced the rear upper and lower bushes earlier this week. Quite easy when one uses the right tools and have access to a hoist. I used the LaserTools http://www.lasertools.co.uk/product/5977 and http://www.lasertools.co.uk/product/5978
The bushes had little to no radial play but quite a bit of axial play, especially the left lower where the play was about 1.5mm. The grease was old and hard and there was a bit of rust in the joint.
The left lower also has two pieces of thin plastic (nylon?) jutting out of it. I assume they were/are the bearing surfaces. As noted above, the "bushes" are Heim/Rose Joints. I'll post pix later.
Cost A$219 for the parts (incl. post). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #467815 9th Feb 2018 1:36am
p38arover
Australia
I never updated this thread. For pix, see http://www.fullfatrr.com/forum/topic13469-15.html Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #477063 29th Apr 2018 5:34am
