![]() | Home > In Car Electronics (L322) > Kardon Harman through model years. |
jeff64 Member Since: 14 Sep 2013 Location: sth.yorks Posts: 14 ![]() ![]() ![]() |
I have a2004 hse it has the k/h 11 speaker system only regret is i cannot have any of the chinese satnav systems in due to it having a DSP amp |
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 ![]() ![]() |
Thanks.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Hi Gents,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
As Mark says, you can fit it and if your amp works it's plug and play.... You can't be far from me, you are welcome to pop round and have a look at it.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Great! Thank you! |
Thanks very much! If I get within striking distance I'll take you up on your very kind offer. |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Hmmm, puzzling this HK Logic 7 setup.
Hi fi wise, yours is the same as the facelift ;
^mjdronfield...many thanks for the info |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Subs are fitted in the passenger side of the boot. You cant see them in the cubby access, they are behind the fixed panel infront of the access flap. They should be there |
