Home > In Car Electronics (L322) > Kardon Harman through model years.
Arkle
I'm new to Range Rover and would like to know at which point the Kardon Harman hi-fi system was introduced and at which model/year it became upgraded. Is the set up in a 2005 superior (more speakers) than a 2003/4?
Any information would be much appreciated.
Thanks.
Paul.
Post #281029 14th Sep 2014 9:35pm
jeff64
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
I have a2004 hse it has the k/h 11 speaker system only regret is i cannot have any of the chinese satnav systems in due to it having a DSP amp Crying or Very sad [/b]
Post #281036 14th Sep 2014 10:32pm
Arkle
Thanks.
Were more speakers added in 2005?
Am I correct in thinking that the Vogue has the better amp and that the TV is upgradeable?
TIA.
Paul.
Post #281039 14th Sep 2014 11:38pm
mjdronfield
Hi Gents,
More info on the hi fi setups here ;
http://www.fullfatrr.com/forum/topic24653....mon+kardon
Info on what can be upgraded on the early BMW based cars here ;
http://www.fullfatrr.com/forum/topic9811.h...w+upgrades
http://www.fullfatrr.com/forum/topic10342....w+upgrades
Haylands has successfully installed a nice fancy new touchscreen system to his car that originally had DSP in it ;
http://www.fullfatrr.com/forum/topic27033.html
The search button is your friend Thumbs Up 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #281040 15th Sep 2014 5:38am
As Mark says, you can fit it and if your amp works it's plug and play....
You can't be far from me, you are welcome to pop round and have a look at it.... Pete
Post #281041 15th Sep 2014 5:48am
Arkle
mjdronfield wrote:
Hi Gents,
Great! Thank you!
Post #281070 15th Sep 2014 9:06am
Arkle
Thanks very much! If I get within striking distance I'll take you up on your very kind offer.
Post #281072 15th Sep 2014 9:09am
Discotigger
Hmmm, puzzling this HK Logic 7 setup.
I've got the pre-facelift 2005 model touchscreen system, with Harmon Kardon Logic 7 (there's a button labelled 'Logic 7' for it in the touchscreen audio settings menu) and I have Logic 7 written on the speakers just underneath the Harmon Kardon labels.
I've managed to locate 13 speakers so far, as follows:
1 on the dash
3 on each of the front doors
2 on each of the back doors
2 on the rear pillars by the tailgate
Haven't looked yet, but need to find the two bass sub-woofers, which I believe are somewhere in the rear left electronics bay?
It's a TD6 Vogue, MY2005 model, pre-facelift...so was this an optional install or standard?
Post #281275 15th Sep 2014 7:52pm
mjdronfield
Hi fi wise, yours is the same as the facelift ;
2005 Facelift
HK system now standard on all models.
Logic 7 now standard on Vogue upwards.
Speakers and amps upgraded compared to equivalent 2002 model year offerings.
The sub will have a larger oval single speaker as oppose to the 2 smaller speakers in the sub on the earlier cars.
The sub is located between the rear boot cubby hole on the left with the nav unit etc in, and the back of the seat, behind the carpeted panel at the side which goes towards the wheel arch. It's not meant to be easy access so you will have to remove some trim if you want to see it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #281341 16th Sep 2014 7:57am
Discotigger
^mjdronfield...many thanks for the info Thumbs Up Bow down
Couldn't see the speaker(s) in the rear boot cubby, not too worried about checking to see if they're there, especially as on the way into work this morning I decided to press the 'Logic 7' button on the touchscreen to see what it was like compared to the regular settings I had. Forgot that I had the volume turned up a bit and nearly sh Censoredt myself when the music came on! Shocked
LOUD, CRISP and CLEAR!!! Oh, and did I say LOUD Shocked Shocked Shocked HOLY COW!!! I could feel the door panels thumping along with my chest at the music.
WOW, what a difference the Logic 7 setting makes, now I'll be able to outdo the Corsa Boys with their little boombox motors Rolling with laughter Rolling with laughter
Mind you, I'll probably need a hearing aid soon, as well Whistle
Post #281377 16th Sep 2014 1:08pm
Subs are fitted in the passenger side of the boot. You cant see them in the cubby access, they are behind the fixed panel infront of the access flap. They should be there Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #281456 16th Sep 2014 8:50pm
