Home > Technical (L322) > Reduced Performance
Page 1 of 4 1234>
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Reduced Performance
I was on my way to the local indie yesterday so they could change my front pads, as I slowed for a 40 the engine started to run rough and then the message appeared 'reduced performance' and they weren't joking about 45 top speed and very very slow to move away. Only a couple of miles to indie so brakes done and diag showed a faulty temp sensor. Discovered the indie can do warranty work so left the car with them, should be fixed on Monday.
Post #274010 2nd Aug 2014 9:19am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Hopefully its covered then... Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #274013 2nd Aug 2014 10:02am
Sandyt
Result if it pans out Thumbs Up Thumbs Up
Post #274078 2nd Aug 2014 9:23pm
Q86ARR
2015 Range Rover Autobiography 5.0 SC V8 Havana
Did the temp sensor fix this issue?
Often a split intake duct causes Restricted Performance on 4.4 TDV8s (usually OSR)
Post #274410 5th Aug 2014 12:35pm
IanV8
Still waiting called yesterday and they had the part but not fitted, will call today.
Ian
Post #274643 6th Aug 2014 9:21am
woodchip
Mines just come up with this tonight, supposed to pick the wife up from hospital tomorrow 35 miles each way. dont know what to do .Damm piece of junk.
Post #274738 6th Aug 2014 9:16pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
It may clear when you turn it off and back on again.
SCs used to do it which was connected to the aux coolant pump being wired up so that it ran back backwards. Rolling Eyes
But as yours is a TDV8 getting the fault codes read is the only real way of understanding what is wrong.
Hope you can use it for the hospital trip ok. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #274740 6th Aug 2014 9:25pm
woodchip
Limped of the motorway, stopped 5 min, started and off again fault cleared so got me home from visiting tonight but do I risk it again. Neutral
Post #274742 6th Aug 2014 9:29pm
SKOT
It's a FFRR, anything could happen! There's every chance you won't see it again! The codes will tell you for sure.
I've had it a few times before. It doesn't actually leave you stranded, it just takes a bit longer to get to where you are going! Whistle 2006 4.2 SC
Post #274743 6th Aug 2014 9:35pm
woodchip
Thats true, a trip to dealer in the morning me thinks to try and at least get the codes read.
Post #274746 6th Aug 2014 9:45pm
Check the top inter cooler hoses for splits, this will cause the problem and is a pretty easy fix with a couple of screwdrivers, well it is on the 3.6....... There is nothing that can't be fixed with a hammer😜😜
Post #274764 7th Aug 2014 7:20am
IanV8
My saga continues, they fitted the sensor and still had the fault so went to fit the sensor to the other bank only to find they are different. Correct one ordered from LR should have been in this morning but did not arrive. Will now have to wait until tomorrow, might have to cancel the weekend away.
Post #274791 7th Aug 2014 9:45am
woodchip
Well, went to local dealer this morning they were so go i am going to name them Kentdale landrover, I explained the reduced performance issue and said I had to pick wife up from the hospital today, so they looked at it straight away.
They did a diagnostic on it which showed a boost pressure fault, not sure on which turbo at this stage, so while I was there we looked at some corrosion problems such as 3 door tops, the black metal frames also the rear tailgate struts and the leaking rear dampers. So it goes in on wednesday for warranty work and I get a Ewok for the day.
Although the reduced performance has to show its face again to give us a clue, I did notice on the m6 tonight from 70mph upwards there is a loss of power but when it then kicks down it is off like hell again.
They did say that the 3.6 does suffer from split turbo hoses but as yet not the 4.4.
Post #274866 7th Aug 2014 7:59pm
Hope its not a turbo, possibly a map/boost pressure sensor gone awry, nice easy fix if it is. There is nothing that can't be fixed with a hammer😜😜
Post #274909 7th Aug 2014 10:37pm
IanV8
Got the call on Friday morning that the car was fixed, went to pick it up only to find it was still sick so they lent me a LR 90 to tow with, bloody awful.
Post #275210 10th Aug 2014 4:49pm
Page 1 of 4 1234>
