![]() | Home > Technical (L322) > Reduced Performance |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
I was on my way to the local indie yesterday so they could change my front pads, as I slowed for a 40 the engine started to run rough and then the message appeared 'reduced performance' and they weren't joking about 45 top speed and very very slow to move away. Only a couple of miles to indie so brakes done and diag showed a faulty temp sensor. Discovered the indie can do warranty work so left the car with them, should be fixed on Monday. |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Hopefully its covered then... |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Result if it pans out |
Still waiting called yesterday and they had the part but not fitted, will call today.
woodchip Member Since: 19 Apr 2012 Location: cumbria Posts: 132 ![]() ![]() ![]() |
Mines just come up with this tonight, supposed to pick the wife up from hospital tomorrow 35 miles each way. dont know what to do .Damm piece of junk. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
It may clear when you turn it off and back on again.
Limped of the motorway, stopped 5 min, started and off again fault cleared so got me home from visiting tonight but do I risk it again. |
It's a FFRR, anything could happen! There's every chance you won't see it again! The codes will tell you for sure.
Thats true, a trip to dealer in the morning me thinks to try and at least get the codes read. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Check the top inter cooler hoses for splits, this will cause the problem and is a pretty easy fix with a couple of screwdrivers, well it is on the 3.6....... There is nothing that can't be fixed with a hammer😜😜
My saga continues, they fitted the sensor and still had the fault so went to fit the sensor to the other bank only to find they are different. Correct one ordered from LR should have been in this morning but did not arrive. Will now have to wait until tomorrow, might have to cancel the weekend away. |
Well, went to local dealer this morning they were so go i am going to name them Kentdale landrover, I explained the reduced performance issue and said I had to pick wife up from the hospital today, so they looked at it straight away.
Hope its not a turbo, possibly a map/boost pressure sensor gone awry, nice easy fix if it is. There is nothing that can't be fixed with a hammer😜😜
Got the call on Friday morning that the car was fixed, went to pick it up only to find it was still sick so they lent me a LR 90 to tow with, bloody awful. |
