Home > Technical (L405) > Smell of fumes from 4.4 SDV8 when driving slowly
Page 2 of 7 <1234567>
RR4ever
United Kingdom 2015 Range Rover Autobiography SDV8 Mariana Black
I had this problem from day 1. It's because with the L405 they moved the pre-heater unit (which operates below 4 deg C) from close to the front wing to underneath the wiper motor unit near the bulkhead. Consequently when reversing in the drive or manoeuvring back and forward at low speed the exhaust fume (burning kerosene or diesel) drifts up through the bulkhead. The exhaust pipe sits in the transmission tunnel but is not long enough to carry the fumes away unless you are driving at a decent speed. I had the Regional Tech Mgr from JLR visit (for suspension knocking issues we all know about) and he confirmed the exhaust pipe is being extended but it takes some time for even such a simple adjustment to work through testing HSE and all the various steps in the "type approval" process worldwide. My friendly technician at at my local dealer tells me the mod will be available end May. MY15.5 SDV8 4.4 A/B FFRR Mariana/Ivory
Ten other FFRR since 2002 either traded in or taken back by JLR
Post #255358 21st Apr 2014 7:27am
SH-UK
France 2014 Range Rover Autobiography SDV8 Mariana Black
Sounds like light at the end of the tunnel with this one hopefully.....
At least with it getting warmer the unit shouldn't cut in so much
I'll pop round to the dealership here in France & ask em when it can be sorted
Thanks for all the info. Off to look at an old defender today, ivory leather & two black labs dont go together!
Cheers
Post #255379 21st Apr 2014 9:24am
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Service action with pipe mod was available last year as my previous post , mine was done and problem solved Far to many gone...
Post #255428 21st Apr 2014 4:25pm
CharlesA22
Scotland 2019 Range Rover Autobiography 5.0 SC V8 Baltic Blue
FBH mod
My car just out from complete FBH and exhaust replacement authorised bt LR. "Many customers been complaining" says dealer. "Hopefully this will fix it"!! Said the dealer. Vehicle off road for 2 days for this and ACE replacement. I will reserve judgement until I have had a few days of normal cold starts (10 deg C and below) FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024
Post #255996 24th Apr 2014 11:15pm
tboner001
Thumbs Up that will solve it Far to many gone...
Post #256017 25th Apr 2014 7:50am
SH-UK
French dealership says there are no updates for this..... Does anybody have the LR details number that I can quote at them, it'll be winter soon enough & that smell is gonna come back...................... Big Cry
Post #273195 28th Jul 2014 8:30am
tboner001
take a look on Topix
https://topix.landrover.jlrext.com/topix/vehicle/lookupForm Far to many gone...
Post #273248 28th Jul 2014 2:32pm
SH-UK
Before I pay Tboner, is this the one I'm looking for?
LTB00590v6 - Heating ventilation & air conditioning odour
Cheers
Post #273544 30th Jul 2014 12:07am
SH-UK
Forget the last post Tboner, I paid & found them, The idea of paying for the documents from land rover over to convince them there's a problem is a bit daft though. May be ask for a refund..................... Whistle Current:-
2014 Defender 90 2.2 TDCi
2014 FFRR 4.4 SDV8 Autobiography
1955 MGTF 1500
Past:-
From a series 2 to 2014 4.4 FFRR Auto. with lots in between
Post #273551 30th Jul 2014 6:57am
tboner001
yup
you only needed the code which is the code off the JLR system anyway , yes i would deff get your money back from the dealer as you are only seeing what a half wit at your dealers has access to ! Far to many gone...
Post #273558 30th Jul 2014 7:37am
RR4ever
This is a known problem with L405 since they changed the siting of the pre-heater (which operates on cold days) from under one wing on L322 to under the bulkhead close to the transmission tunnel on L405. LR thought in their wisdom the forward motion of the vehicle would carry the pre-heater exhaust fumes down the underside of the vehicle and then dissipate. What they didn't realise (or test fully enough) was if you end up reversing or doing a three-point turn getting the vehicle out of the drive/parking spot the exhaust fumes don't travel down the vehicle underside but find their way immediately up through the bulkhead into the front cabin. Hence the smell of kerosene. I understand the solution they have come up with is to extend the length of the pre-heater exhaust pipe so that it takes fumes down the underside of the vehicle. I first complained of this last October and the solution is still being field trialled (or so I'm told). I'm still waiting for the fix. MY15.5 SDV8 4.4 A/B FFRR Mariana/Ivory
Post #273730 31st Jul 2014 8:20am
tboner001
correct as above , field testing lol now that is funny ,
mine was fixed last year , and the service action notice came out last year Far to many gone...
Post #273737 31st Jul 2014 9:06am
SH-UK
LTB00556, if I could attach it I would! that'll be 15 quid please........................ Twisted Evil Current:-
1955 MGTF 1500
Past:-
Post #273771 31st Jul 2014 11:42am
tboner001
yes exactly came out last year
Thumbs Up Far to many gone...
Post #273788 31st Jul 2014 2:05pm
CharlesA22
FBH Fumes in cabin
My car had a complete new FBH and exhaust pipe replacement authorised by JLR and carried out 24/04/2014. Problem has recurred 3 times since, largely because ambient temperature has not been low enough to cause the FBH to kick in on cold starts. I fully expect to be back at the dealer in the late autumn as this defect of design has not been rectified yet. FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024
Post #274021 2nd Aug 2014 12:26pm
