Home > Technical (L405) > Smell of fumes from 4.4 SDV8 when driving slowly
Page 3 of 7 <1234567>
Q86ARR
2015 Range Rover Autobiography 5.0 SC V8 Havana
LTB00556 only applies to petrol variants
LTB00590v6 refers to a concentrated bad smell from the AC when switched on.
Post #274661 6th Aug 2014 1:18pm
SH-UK
France 2014 Range Rover Autobiography SDV8 Mariana Black
Yep you're right, just re-read it, Still think I can use it as ammunition though........... Twisted Evil
The problem exists & therefore should be fixed Evil or Very Mad Current:-
2014 Defender 90 2.2 TDCi
2014 FFRR 4.4 SDV8 Autobiography
1955 MGTF 1500
Past:-
From a series 2 to 2014 4.4 FFRR Auto. with lots in between
Post #275042 9th Aug 2014 2:29am
CharlesA22
Scotland 2019 Range Rover Autobiography 5.0 SC V8 Baltic Blue
Re: FBH Fumes in cabin
CharlesA22 wrote:
My car had a complete new FBH and exhaust pipe replacement authorised by JLR and carried out 24/04/2014. Problem has recurred 3 times since, largely because ambient temperature has not been low enough to cause the FBH to kick in on cold starts. I fully expect to be back at the dealer in the late autumn as this defect of design has not been rectified yet.
Return of autumnal temperatures has brought with them a daily dose of fumes from the FBH on my car. Back into dealer on Tuesday for the 10th Warranty visit!! FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024
Post #288970 26th Oct 2014 12:48pm
scott4197
United Kingdom 2018 Range Rover Vogue SDV8 Baltic Blue
@CharlesA22, I am wondering if your dealer had any success addressing the problem with the fumes?
Please update us with any news!
Thanks in advance.
Post #292009 10th Nov 2014 4:34pm
RR2008HSE
The UK seems to have good consumer protection laws. Do you have anything like the California Lemon Law? The dealer gets three tries to fix a given fault on a new car. After that, the customer can make him take back the car. It's then branded as a "lemon" in any further sale. That gives the dealer a rather big incentive to fix it properly the FIRST TIME!
Post #292132 11th Nov 2014 2:56am
CharlesA22
Thanks in advance.
Disappointed to report that the local dealer, who had the car for a week whilst I was out of the country, has failed to find any fault. Advised by receptionist that the only relevant technical bulletin they could find was the one relating to Petrol cars and deemed not relevant to my Diesel car. Technician not available to challenge when I collected car. Maybe they'll fix it on the 11th Warranty visit sometime soon!!! FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024
Post #292178 11th Nov 2014 12:08pm
scott4197
My local dealer said the same.
Apparently diesel fumes get discharged underneath the car.
It is strange as the exhaust doesn't smell of diesel fumes because of the catalytic converter.
Out of interest, what kind of problems have caused the other 10 warranty visits?
Post #292319 11th Nov 2014 10:03pm
CharlesA22
In response to your request for information on the now 11 warranty visits (post delivery):-
Defect/ Malfunction Warranty visit
Faulty instrument pack 0
Gear selector software fault 1
Metallic zing from heat shields 1 & 8
Fuel Burning Heater "Paraffin" smell in cabin 1, 2, 3, 4, 7 & 10
Front suspension noise 1, 4, 7 and 8
Rear windscreen wiper stopped mid -journey 2
DPF sensor clogged. Breakdown call out 5
Non Compliance Recall - Double speed flash tell tale sounder 6
Parallel park software malfunction 8 & 9
Door lock failure to release 9, 10 & 11 FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024
Post #294951 24th Nov 2014 4:23am
vanquishspirit
I was wondering if anyone has finally got to the bottom of this. I have a 63 plate 4.4SDV8 Autobiography and since the weather has got a little colder the smell has started to find its way into the interior of the car. One small journey resulted in the car filling with a grey fog. I am now finding its making me lose my voice as the fumes are really quite excessive. It reminds me of the smell you get in a jet airliner on the ground but stronger. It has been back to check it had the software update to reduce the amount the FBH fires, that was upto date and has had the extended exhaust pipe fitted but again that's not resolved it. All this without using the cabin pre heat function, but if I did then when you get into the car its stinks. Not on for a £100k motor car. I have had 12 plus Rangies over the years, but in spite of all the problems, they have never tried to poison me until now. Land Rover really know how to treat their customers! I have been back onto customer services who are getting the car back to my local dealer and providing technical support to the dealer to ensure they resolve it. Cannot see how they can if its a design fault which it seems to me it probably is. 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
1972 Suffix A fully restored 2 door
1970, chassis number 26 the first of the press launch cars, Masai Red
2013 4.4SDV8 Autobiograpahy
Post #295400 27th Nov 2014 10:00am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Try and get it in to your next press article. letters not necessarily in the right order
Post #295478 27th Nov 2014 6:22pm
vanquishspirit
Which article is that Dixy? 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
Post #295534 27th Nov 2014 9:28pm
CubaLibre
According the the WM, "In order to minimize the potential for odor ingress from the FFBH, the ATCM will automatically close the recirculation door in the climate control assembly for the first 7 minutes of FFBH operation when activated by the timed climate control feature."
Post #295676 28th Nov 2014 3:55pm
vanquishspirit
thanks for this. But is this what is programmed to happen , or is this an update? the dealer was asking me whether I had the recirculation button pressed when starting the car in cold weather but I rather suggested that I should not have to think about that. I have had two calls from LR today which I missed so maybe they have something to offer me as a solution. 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
Post #295721 28th Nov 2014 6:25pm
CubaLibre
This is simply what's written in the WM
Post #296329 1st Dec 2014 5:39pm
CharlesA22
In reply to vanquishspirit, I too believe this to be a fundamental failure of design and an inadequate test regime that failed to reflect normal use of the vehicle in cool, even if not cold, conditions. The reference to the WM content from CubaLibre is interesting, but in that it specifically relates to the Timed Climate Control feature it is not relevant to this issue. The defect of design relates to the relocation of the FBH from its forward positions on previous models (L322, Disco etc.,) to a position closer to the passenger cabin and ventilation air intakes. The FBH does not require any manual (remote) or timed input to generate the fumes, although these too will cause the problem albeit self-inflicted by the user. All that is necessary to inflict the problem is a cool temperature start with some extended manoeuvring such as toing and froing to exit a tight parking space. A standard feature for us city dwellers. No doubt the LR test team performed multiple cold starts in many conditions which automatically fired the FBH, but if they then accelerated off into the sunset the problem would simply be whisked away by the airflow.
My local dealer has diligently executed all of the guidance specified by JLR, replacing the exhaust, extending it and even a complete new FBH assembly. The last visit he was simply told to apply more tape/gunk to secure the exhaust pipe on the inside of the wheel arch. All to no discernable improvement. If that is not indicative of a fundamentally flawed design, then what is. I am even advised that some fed up users have asked for their FBH's to be permanently disabled because of JLR's failure to provide a remedy!! FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024
Post #296710 3rd Dec 2014 1:10am
