![]() | Home > Technical (L405) > Smell of fumes from 4.4 SDV8 when driving slowly |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Only diesels have an FBH Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3215 ![]() ![]() ![]() |
@Dr Rob
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi what is the fix for this problem. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
piston Member Since: 06 Feb 2021 Location: Kent Posts: 18 ![]() ![]() ![]() |
It’s probably the EGR cooler leaking and it’s sits behind the engine. Mine went the same way with loads of fumes in the cabin |
Hi was this issue with EGR cooler leak only intermittent upon giving the car some hi revs etc..The smell is sweet like gas smell it’s horrendous and the smoke is mainly right at back of engine. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
StevieBoy Member Since: 12 Dec 2023 Location: Surrey Posts: 14 ![]() ![]() ![]() |
Am curious - did jp0580 get a diagnosis & solution - was it the EGR valve?
