![]() | Home > Technical (L405) > Smell of fumes from 4.4 SDV8 when driving slowly |
SH-UK Member Since: 13 Mar 2014 Location: Dordogne-shire.... Posts: 33 ![]() ![]() ![]() |
Sounds like light at the end of the tunnel with this one hopefully.....
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
Service action with pipe mod was available last year as my previous post , mine was done and problem solved Far to many gone... |
CharlesA22 Member Since: 08 Jan 2014 Location: Strathclyde Posts: 33 ![]() ![]() ![]() |
My car just out from complete FBH and exhaust replacement authorised bt LR. "Many customers been complaining" says dealer. "Hopefully this will fix it"!! Said the dealer. Vehicle off road for 2 days for this and ACE replacement. I will reserve judgement until I have had a few days of normal cold starts (10 deg C and below) FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024 |
French dealership says there are no updates for this..... Does anybody have the LR details number that I can quote at them, it'll be winter soon enough & that smell is gonna come back...................... |
take a look on Topix
Before I pay Tboner, is this the one I'm looking for?
Forget the last post Tboner, I paid & found them, The idea of paying for the documents from land rover over to convince them there's a problem is a bit daft though. May be ask for a refund..................... |
yup
RR4ever Member Since: 14 Aug 2013 Location: Hertfordshire Posts: 21 ![]() ![]() ![]() |
This is a known problem with L405 since they changed the siting of the pre-heater (which operates on cold days) from under one wing on L322 to under the bulkhead close to the transmission tunnel on L405. LR thought in their wisdom the forward motion of the vehicle would carry the pre-heater exhaust fumes down the underside of the vehicle and then dissipate. What they didn't realise (or test fully enough) was if you end up reversing or doing a three-point turn getting the vehicle out of the drive/parking spot the exhaust fumes don't travel down the vehicle underside but find their way immediately up through the bulkhead into the front cabin. Hence the smell of kerosene. I understand the solution they have come up with is to extend the length of the pre-heater exhaust pipe so that it takes fumes down the underside of the vehicle. I first complained of this last October and the solution is still being field trialled (or so I'm told). I'm still waiting for the fix. MY15.5 SDV8 4.4 A/B FFRR Mariana/Ivory
correct as above , field testing lol now that is funny ,
LTB00556, if I could attach it I would! that'll be 15 quid please........................ |
yes exactly came out last year
My car had a complete new FBH and exhaust pipe replacement authorised by JLR and carried out 24/04/2014. Problem has recurred 3 times since, largely because ambient temperature has not been low enough to cause the FBH to kick in on cold starts. I fully expect to be back at the dealer in the late autumn as this defect of design has not been rectified yet. FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024 |
