Home > Technical (L322) > Faults everywhere and IID tool not working! |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2938 |
I tried 0000 and it worked.
31st May 2014 1:58pm |
Bit of an update:
1st Jun 2014 11:26am |
Sounds exactly like what I had, Noddy. I assume you found no direct traces of humidity by what you are writing?
2nd Jun 2014 8:09am |
It's still faulting. I've yet to get a few hours where I can look at this properly.
2nd Jun 2014 8:22am |
I reset it again tonight in the car park at work. As soon as I turned the steering wheel, it faulted again. HDC inactive and Airsusp inactive
2nd Jun 2014 6:23pm |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 |
Would be worth looking at the steering angle senor live value. These have been known to fail... |
2nd Jun 2014 6:28pm |
Ok.... What am I looking for? |
2nd Jun 2014 6:30pm |
When the wheels are straight, it should be equal to 0. Slowly turn the wheel in one direction. The value should change accordingly. If you see it jumping quickly, your sensor is not working properly. |
2nd Jun 2014 7:42pm |
I think I've found the fault.
3rd Jun 2014 10:57am |
Here you go...
3rd Jun 2014 4:33pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Well done Noddy, glad you found the fault. |
3rd Jun 2014 5:11pm |
Pat, I would use shrink tubing but I can't get it over either end of the cable. There's a black box at one end and the other goes to the unit on the back of the hub.
4th Jun 2014 3:41pm |
Indeed, shrink tube is sometimes hard to fit !
4th Jun 2014 4:00pm |
So, you crashed the CAN (isn't that an ancient song by Suzy Quattro or someone?).
4th Jun 2014 4:31pm |
