Home > Technical (L322) > Faults everywhere and IID tool not working!
Page 1 of 3 123>
Andy
I'm out and about at the moment and ive just had hdc inactive appear on the dash. Parked up, turned the car off and restarted and the faults cleared. However, I now have no indicators and there are several warning lights I the dash- abs, brake pads etc. the lo range light is also flashing. The sat nav screen is also flashing the splash screen intermittently.
To make matters worse, I've just plugged in the IID tool and that's not coming on either!
Any help appreciated!
Post #262096 29th May 2014 12:29pm
battery i think Andy.. ... - .- -.
Post #262098 29th May 2014 12:34pm
Andy
It's turning over and starting ok though?
Yestersday, the splash screen stayed on. When I went to restart it, it was asking for a code. Thankfully, I had the code and it's started.
Post #262099 29th May 2014 12:35pm
if its possible do the battery disconnection thing and have the battery checked out.. ... - .- -.
Post #262100 29th May 2014 12:42pm
Andy
If it is the battery, this will be the 2nd time I've replaced it. It's the larger Bosch unit with a five yr guarantee. I've just got home and the indicators are working, just not ticking on the dashboard.
Abs lights are still on and the suspension has locked but no fault message this time?
I've plugged it into the charger so we'll see what happens
Post #262102 29th May 2014 12:54pm
try the disconnection first Andy ..this will reboot all the ecu's that possibly were not getting full power. ... - .- -.
Post #262104 29th May 2014 1:10pm
Andy
Just done that. No lights on the dash at the moment, but no splash screen at all now and indicators still not ticking.
No IID tool either.
Charging as we speak.
Post #262106 29th May 2014 1:26pm
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Could be alternator I would check the voltage with engine running The difference between theory and reality is that in theory it will work.
Post #262115 29th May 2014 2:01pm
Key battery low ? .
Post #262125 29th May 2014 2:50pm
Andy
How would that affect the vehicle?
Post #262128 29th May 2014 3:10pm
Andy
No radio either. Every time I press the radio button, the splash screen comes on briefly.
Proper gremlins this time!
Anyone?
Post #262175 29th May 2014 7:13pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Burn it noddy Big Cry 1994 softail full stars n stripes custom harley davidson
Post #262177 29th May 2014 7:19pm
Keep a calm head and start with the basics... Battery reset, fuses, walk away for 10mins & have a cuppa Thumbs Up
Post #262233 29th May 2014 11:16pm
SteveMFr
Site Sponsor
Hi Noddy,
I actually had a similar issue in my TD6 last autumn that ended up costing me a €400 tow Shocked
In my case my younger daughter had hit the rear hatch release button on the key one night before a heavy rain (hatch was open one 'click') - and everything in the electronics compartment was wet. Seems the iBus crashed the CAN. I couldn't even start, tho.
I had similar symptoms: no indicators, satnav screen blank, etc. And no diagnostic system will work if the CAN is crashed.
You may have another cause to your prob, but something is blocking comms on the busses.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #262281 30th May 2014 11:15am
"Asking for code" made me think key ?
What code did you need to enter out of interest ? I don't "have" any codes for my FFRR ? .
Post #262339 30th May 2014 5:32pm
Page 1 of 3 123>
