Home > In Car Electronics (L322) > Fitting Paddle shifters to a 2007 FF
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
You can buy these from powerful UK >.
http://www.powerfuluk.com/products/range-r...e-kit.html
I understand that they have been successfully retrofitted to 2002-2005MY, but does anybody know if and how they can be fitted to a 2007MY?
Anybody point me in the right direction on this? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #260727 21st May 2014 4:20pm
mzplcg
I don't know but have been researching it based on my 2010 not having the paddles which the diesels have. That turns out to be the 8 speed box not being fitted to the S/C which mean I effectively have the 06-09 6hp28 gearbox that you have and I would quite like the paddles.
Not sure what it might do to the gearbox ecu though as that wasn't designed with paddles in mind in the RR. However, that same 6hp28 box (sans transfer box) was fitted to the Jag XF and that does have the paddles. It also has the round pop-up gear knob though so I'm guessing the ECU (inside the box I think) must be a bit different as it does behave differently based on various other modes/settings.
I think we need RRPHIL and possibly someone from GAP or BlackBox to sort the electrickery. I would hazard a guess that the paddles are connected to the CANBUS or something similar, not directly to the gearbox ECU.
Post #260737 21st May 2014 6:34pm
B3EEE
2005 Range Rover Supercharged 4.2 SC V8 Tangiers Orange
to change up or down, I just use the acceleration pedal - thats what one does with automatics ?  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #260738 21st May 2014 6:39pm
mzplcg
Yeah, there's always one. Really helpful and constructive comment. Rolling Eyes
Post #260740 21st May 2014 6:42pm
paulmoran2
Cheers Mzplcg....this might be a daft thing to suggest, but surely it's a case of bypassing the switches that are actuated when the gear stick is pushed forward or back in manual mode? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #260758 21st May 2014 8:01pm
here's the thread re matts early FF paddle conversion,
http://www.fullfatrr.com/forum/topic6133.html?highlight=paddles
and some more info re a 2007 job,
http://www.fullfatrr.com/forum/topic9591.html?highlight=paddles
and some more info,
http://www.fullfatrr.com/forum/topic10718.html?highlight=paddles ... - .- -.
Post #260773 21st May 2014 8:48pm
Just for info the 5.0sc does have the 6hp28 but it is an uprated version of the 6hp26 in the 4.2 sc and tdv8, i reckon it could be done but it wouldnt be too easy, i think the paddles would normally connct to the cars bus, so separate wires
Would have to be runto the microswitches on the gearbox to override them. There is nothing that can't be fixed with a hammer😜😜
Post #260775 21st May 2014 8:52pm
paulmoran2
Cheers gents Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #260779 21st May 2014 9:04pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
You can definitely retrofit paddles on a 5.0 SC. They were fitted from 2011 onwards and are easy to fit on 2010, there's a thread about this on rangerovers.net I think.
Post #260805 21st May 2014 10:27pm
RR2008HSE
The 06-09 car has a manual mode, so it shouldn't care how that's activated. A switch is a switch. If there was no manual mode, then I think you could get some trouble.
Post #260819 22nd May 2014 12:20am
mzplcg
Good shout. Not found the thread yet but did check out a pic of a 2011 S/C on the used LR site. See below.
EDIT.
OK, I found the thread on the other side HERE
So, it seems that if you add this mod it has to be turned on in the CCF (there is mention if it being in the body control module) and it behaves as my wife's XF does. See post 25. THis being the case and the fact that the same basic gearbox is in both cars there is probably an ECU difference to enable this, maybe something as simple as a firmware upgrade.
However, I'm not sure when they went from the 6hp26 box to the 6hp28 in the full-fat. In Disco it seems to be 2006 and again I believe it was mainly an upgrade to get rid of the 2nd gear to 1st gear 'bang' and to handle the extra torque of the TDV8 so it should be similar enough to possibly connect up in the same way.
In all cases it will need a diagnostics tool to enable the option and this is where I think the 06 to 09 cars will be most likely to fail in as much as the option probably won't be there. Maybe ask the GAP chaps to chip in on this point.
Keep reading then. Very Happy
Dom.
Post #260825 22nd May 2014 4:31am
mzplcg
OK, after a bit more reading and having examined the inside of teh steering wheels on a 2008 and my own 2010 it seems the problem with the 06 to 09 cars is the lack of a connection port to the canbus in the steering wheel switch modules and the fact that LR changed their canbus from 29 bit to 11 bit at the 2010 change (might have been other way around)
The 2010 onwards with the updated switch packs has the connector so they can just be plugged in. Happy days there.
But I think the paddles as they are, even if they can be connected to the canbus somehow, will have the wrong message length for the older canbus to recognise. Even if it was what they know as a remote message I doubt the trigger frame from the paddles would be in the correct format. It's right now I wish I understood canbus a bit more Big Cry
So, if my thoughts are correct then the best way would be to modify the paddles to become pure microswitches and use standard wire to splice them into the + and - switches on the command shift side of the gear lever. That still leaves the small matter of getting the wire from the steering wheel down to the console. Unless you have the non-heated wheel (HSE only I think) there aren't any spare connectors in the clock spring pack. The guys with the earlier cars might be able to help here but I never had a pre 06 car personally so I don't really know but several people have done this mod on an early car and there's a youtube video on how to modify the switches.
Probably not what you wanted to hear I suspect but good luck anyway.[/code]
Post #261025 23rd May 2014 6:07am
paulmoran2
@ Mzplcg...Going to go down the simple approach / route to see if I can just link in to the micro-switches (if there are such things fitted) that are normally actuated when the gear select lever is pushed forward or back (+/_) to the paddles by hard wiring or a remote wireless link. That then bypasses any electronic trickery. Anything more than that..i'll forget about it Sad GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #261054 23rd May 2014 8:49am
CSK
Forget about it, they're pretty useless! I never change manually with so much torque on hand.
Post #261099 23rd May 2014 1:11pm
paulmoran2
@ CSK ....Have them on my XF and love / use em every day...bit of a gadget lover...my toys are usually just for the sake of it, just like the Ipod intergration kit Dan has just sent to me...I use the Aux currently, but prefer a shiny new toy to play with Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #261103 23rd May 2014 1:29pm
