Home > In Car Electronics (L322) > Fitting Paddle shifters to a 2007 FF |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
You can buy these from powerful UK >.
21st May 2014 4:20pm |
I don't know but have been researching it based on my 2010 not having the paddles which the diesels have. That turns out to be the 8 speed box not being fitted to the S/C which mean I effectively have the 06-09 6hp28 gearbox that you have and I would quite like the paddles.
21st May 2014 6:34pm |
Yeah, there's always one. Really helpful and constructive comment. |
21st May 2014 6:42pm |
Cheers Mzplcg....this might be a daft thing to suggest, but surely it's a case of bypassing the switches that are actuated when the gear stick is pushed forward or back in manual mode? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
21st May 2014 8:01pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
here's the thread re matts early FF paddle conversion,
21st May 2014 8:48pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
Just for info the 5.0sc does have the 6hp28 but it is an uprated version of the 6hp26 in the 4.2 sc and tdv8, i reckon it could be done but it wouldnt be too easy, i think the paddles would normally connct to the cars bus, so separate wires
21st May 2014 8:52pm |
Cheers gents GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
21st May 2014 9:04pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
You can definitely retrofit paddles on a 5.0 SC. They were fitted from 2011 onwards and are easy to fit on 2010, there's a thread about this on rangerovers.net I think. |
21st May 2014 10:27pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
The 06-09 car has a manual mode, so it shouldn't care how that's activated. A switch is a switch. If there was no manual mode, then I think you could get some trouble. |
22nd May 2014 12:20am |
Good shout. Not found the thread yet but did check out a pic of a 2011 S/C on the used LR site. See below.
EDIT. OK, I found the thread on the other side HERE So, it seems that if you add this mod it has to be turned on in the CCF (there is mention if it being in the body control module) and it behaves as my wife's XF does. See post 25. THis being the case and the fact that the same basic gearbox is in both cars there is probably an ECU difference to enable this, maybe something as simple as a firmware upgrade. However, I'm not sure when they went from the 6hp26 box to the 6hp28 in the full-fat. In Disco it seems to be 2006 and again I believe it was mainly an upgrade to get rid of the 2nd gear to 1st gear 'bang' and to handle the extra torque of the TDV8 so it should be similar enough to possibly connect up in the same way. In all cases it will need a diagnostics tool to enable the option and this is where I think the 06 to 09 cars will be most likely to fail in as much as the option probably won't be there. Maybe ask the GAP chaps to chip in on this point. Keep reading then. Dom. |
22nd May 2014 4:31am |
OK, after a bit more reading and having examined the inside of teh steering wheels on a 2008 and my own 2010 it seems the problem with the 06 to 09 cars is the lack of a connection port to the canbus in the steering wheel switch modules and the fact that LR changed their canbus from 29 bit to 11 bit at the 2010 change (might have been other way around)
23rd May 2014 6:07am |
@ Mzplcg...Going to go down the simple approach / route to see if I can just link in to the micro-switches (if there are such things fitted) that are normally actuated when the gear select lever is pushed forward or back (+/_) to the paddles by hard wiring or a remote wireless link. That then bypasses any electronic trickery. Anything more than that..i'll forget about it GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
23rd May 2014 8:49am |
Forget about it, they're pretty useless! I never change manually with so much torque on hand. |
23rd May 2014 1:11pm |
@ CSK ....Have them on my XF and love / use em every day...bit of a gadget lover...my toys are usually just for the sake of it, just like the Ipod intergration kit Dan has just sent to me...I use the Aux currently, but prefer a shiny new toy to play with GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
23rd May 2014 1:29pm |
